Results 1 to 5 of 5
Thread: Air flow Meter Mod Vs
    vs commodore
    Mar 2010
    Default Air flow Meter Mod Vs
    A few years ago i found a page on the net that had a guide to removing the mesh inside your air flow meter on a vs commodore , will it stuff up my air flow readings if i remove the mesh or will it allow more air to pass threw , just wondering what your opinions are on removing it cheers .
    I have attached a photo of the mesh in the air flow meter .
    VS Berlina 3.8
    Dec 2008
    Don't. Any gain you get will be so marginal it won't be worth doing, especially on a stocker.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    .....also, the mesh is there to protect the fine sensing wire.
    If something in the air stream hits the sensor wire......goodbye sensor.
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    As stated, terrible idea. Won't make any worthwhile difference.
    Sam
    WTB: mulberry VN interior parts
    vs commodore
    Mar 2010
    Cheers guys luckily i asked before i went and starting hacking at the mesh
LinkBacks (?)
  1. 18-11-2010, 11:38 PM
  1. air flow meter
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2008, 01:27 PM
  2. Vt air flow meter
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:22 AM
  3. LS1 air flow meter
    By I LIKE COMMODORES in forum General
    Last Post: 01-09-2005, 02:43 PM
  4. Air flow meter...
    By stylen in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2005, 02:03 PM
  5. vl air flow meter
    By psi berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-06-2005, 09:07 PM
