Results 1 to 3 of 3
Thread: Stalling V6 Ecotec
    95 VS Berlina
    Mar 2010
    Western Suburbs Of Adelaide
    Default Stalling V6 Ecotec
    Recently i had an issue with my car stalling. I got code 46 come up and replaced my harmonic balancer, crank angle sensor, still had the same problem! Replaced my cam angle sensor. Still had the problem. I got some advise of a mate who had a similar problem. I removed the coil packs and the plate they mount onto. Then simply get some emery tape or sand paper clean up the plate on the motor side and under the coil module then it worked. Spent alot of money for something i could have fixed for nothing. I was just a dirt contact.
    VS 5.0 HDT spec 195i
    Jul 2009
    Wollongong
    Code 46 is ignition no spark or injector pulse so you were on the right track. It was because the coil pack was not grounding to earth corretly.
    95 VS Berlina
    Mar 2010
    Thats exactly right. Being a mechanic i should have realised. Just hoping it could save someone the expense
  1. engine swap from vs ecotec to vr s/wagon(non ecotec)
    By gumby05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2010, 06:33 PM
  2. stalling problem! vx ecotec
    By Gurezy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2009, 05:26 PM
  3. [Ecotec] ecotec auto to ecotec manual conversion
    By jimmythefish in forum V6 Development And Modification
    Last Post: 12-11-2009, 04:44 PM
  4. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  5. WTB: RECO VS ECOTEC or ECOTEC STROKER
    By Cursed CX8 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-09-2008, 12:15 AM
