hi all has anyone on here replaced the dizzy on a vr 5.0l without taking the Vally off or dropping engine mounts thanks...
ok your lengthy reply was much appreciated again thank you
yer i was hopping for some help on this i sort have figured it was the hall effects bye post reply and looking at the dizzy looks like a c..t to change. only been on this site for a few weeks and didn't think the members on here were as picky as other sites i look at. it seems to be an obvious question i was asking i my have been short in my question if so im sorry but it seemed obvious to me
OK thanks for that at lest i know it can be removed with engine complete will be having a crack at it as soon as get a new dizzy
that was my next question... seen dizzy s on flebey for about $80 when i rang the commo shop today the said 280 for a recon one so if the e bey one,s are crap maby ill be looking at pulling mine out and replacing the hall effects in it
will do should be cheaper exchange
Put some loctite anti sieze on the dizzy shaft O ring area so next time you remove it, it will slide out with ease.
copy that thanks
