Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: VR Acclaim - Rotors Will not come off
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Default Please Delete this!
    Thread has become over ridden with Scrap comments, please delete this thread
    Life starts at 200km/h
    Mar 2009
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    They must be rusted on. If you are going to replace them then just keep bashing with a big hammer. If you don't want to damage them keep spraying with WD 40 or a rust dissolver and give it lots of time to penetrate. Oh and jacking it off isn't going to get the job done.
    MY RIDE
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    dust cap, big nut? i thought the rotors slid away, with some love of course.. which nut/dust cap
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by accentstencil View Post
    i knew it sounded wierd at the time, i used a scissor just to try and push it off, by winding the jack higher if it makes sense
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    thats if you wanna take the whole hub assembly off, just belt the **** out of it with a hammer keep changing where you hitting it from memory they are a "floating" type of rotor and are held on by the wheel and caliper(no bolts on in the actual rotor)
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    Mar 2009
    vs commodore
    Oct 2009
    Tamworth NSW
    The nut behind the cap is only on models up to VP.The VR and later models use the sealed front bearing/hub and the disk is just a sliding fit over the hub.Nothing holds it there except the wheel and the wheel nuts.I had the same trouble when I replaced my hubs.I bashed the disk with a rubber mallet after Id soaked it in wd-40 overnight.They finally came off after a lot of hitting.
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    these are a pain, the get rusted on over time. buy a can of penetrene or similiar and spray around the centre of the hub and let it sit fora while then spray again if necessary. then you can belt it with a rubber mallet and turn the hub 180 degrees each time and eventually it will give.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    In the past i have to kick wheels off the front hubs coz of the corrosion of the front hubs , once used a three jaw puller to remove a ford xf mag wheel , worst comes to worst drill and tap the rotor with a M10 thread in two places and wind two bolts into the rotor to push of the hub use plenty of wd-40 rost off crc , spray from the front and back off the rotor around the wheel studs and hammer away until they came off .
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by impulsive View Post
    Sorry, but it was an attempt at humour. Using a jack was a good idea really.
    MY RIDE
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I just beat the shit out of the ones on my old 5L, no mercy. Put a skinny bit of wood in the way to soak up the worst of the damage and go to town on it with a steel hammer
    Sam
    WTB: mulberry VN interior parts
    VR S2 Commodore remote turbo
    Nov 2009
    Mount Isa
    I was sure there a three 10mm allen key bolts holding the hub assembly to the steering knuckles??? you have a vr yes?
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    thanks for the input guys, should of mentioned id like to keep the rotors, they are in fair good nick, carf has done F All KM for a long time and they were replaced not many KM ago
  15. #15
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by darthdingas View Post
    yeah def VR, where abouts are these 3 bolts??
  16. #16
    Nov 2003
    On the reverse side of the disc. They are the only allen key bolts there.
  17. #17
    Feb 2009
    longford, victoria
    what are you pulling the rotors off for?
    my geminis
  18. #18
    strgas's Avatar
    Oct 2009
    try a hammer and punch from the inside of the rotor hub to avoid hitting the disc surface
  19. #19
    VS 5.0 HDT spec 195i
    Jul 2009
    Wollongong
    The brake rotors are not bolted on. There are 3 bolts on the hub only which do not need to be removed if your just removing the rotors. Just be patient and take your time and hit them off from the back of the rotor with a copper faced hammer. The use of penetrine or wd40 etc, will help a lot.
  20. #20
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
  21. #21
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by nemesis_adrasteia View Post
    restoring the car, need to clean it up a bit mate
  22. #22
    Nov 2003
    another couple of hours bashing the rotors, still no movement
    It maybe quicker to remove it at the hub and hit the hub from it. I had to replace the hubs on the VT over the weekend, no amount of hitting the disc would budge it. I thought stuff it, I am taking the hubs off anyway. I undid it at the hubs layed them on some newspaper and a couple of tabs with the hammer on the hubs had it drop away from the disc.
  23. #23
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    when i did my brakes a few months back the rears were rusted on well too, no amount of percussive maintenance would convince them to come off. grabbed a 10inch 3 jaw gear puller and had them off in about 2 minutes
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
  24. #24
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Oxy Torch ?? It may just need a bit of heat to losen the rust.
    Or try hitting around the hub, near the disc.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  25. #25
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Quote Originally Posted by woteva View Post
    Heat will screw the discs, which i will need while restore is underway, have tried hitting there mate thanls
  1. RDA disc rotors vs DBA rotors
    By Aus78Formula in forum General
    Last Post: 22-11-2011, 09:05 PM
  2. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
  3. Rotors
    By Ryaz11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 09:36 AM
  4. Replies: 20
    Last Post: 15-01-2008, 01:42 PM
  5. 10 stud vs 5 stud Rotors on Back of IRS VS Acclaim
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 09:43 PM
