Results 1 to 7 of 7
Thread: VR engine died while driving
    VY SV8 Supercharged
    Feb 2010
    WA - SOR
    Default VR engine died while driving
    Driving along the road at 50kph and all of a sudden the engine dies, couple of lights came up on the dash so i pulled over.
    Would crank but not fire when trying to restart.
    So went uunder the bonnet, remembered that a few people have problems with the alternator and that kills the engine while driving and lights come up on dash all like mine did, gave the alternator a couple of thuds with the palm of my hand.. and the car started again and drove home fine.
    Would like to mention car has had problems starting 3 times in the last 3 weeks, cranks forever but wont fire. leave it for a few minutes and then it turns on fine.
    Anyone like to shed some light and tell me if the alternators on the way out, or if i need to get the bushes done etc.
    Any help or direction would be good thanks
    vs2 berlina 96 3.8 auto hsv plated
    Sep 2008
    brisbane nth
    Same thing with VS 6/96 V6 Berlina. Has something to do with the immobiliser ? (read in previous thread) When it won't start straight away the red light under the clock on the radio blinks once then it starts. When it starts straight away, that red light doesn't come on at all.
    Yet to see the red light when the motor cuts out on hwy. Also when the motor won't start at all. Seems that I just have to wait for 5-10 minutes then it starts again. Got me stumped too.
    Kind Rgds
    Dave
    vs commodore
    Oct 2009
    Tamworth NSW
    Sounds like a crank angle sensor (CAS) is on its last legs.What you say about the engine cutting out and starting again a few minutes later is very similar to what a stuffed CAS will cause.
    VY SV8 Supercharged
    Feb 2010
    WA - SOR
    So anyone got any ideas to what my problem is, alternator? small battery (its only a tiny 270cca)? CAS?
    vs commodore
    Oct 2009
    Tamworth NSW
    You are gonna have to try swapping things like the CAS.Maybe a mate will let you borrow his sensors etc to test on your car or pick up some second hand ones from the wreckers to use for the tests..Theres no point trying to guess the problem without trying other sensors or DFI modules etc.As you test stuff you can then rule it out as being the cause of the problem.A small battery is not gonna make the engine stall or play up.Also get a multimeter and check the battery voltage with the engine running and headlights on.It should be around 13 volts or more.If it shows a low voltage reading(around 12 volts or less),the alternator or its regulator is likely to be knackered.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If it were mine, I would fit a new GENUINE Crank Angle Sensor. I fitted a new one to my VS (and a new fuel pump) the second day I owned it. Cheap insurance.
    A mate of mine who runs a workshop, recommends to his customers a new one be fitted every 100,000kms.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    try checking error codes when it stalls or even just after it wont start, cas will lodge a code when foulting, tech 1 will pick it up as a history code if you have that sort of luxuary
LinkBacks (?)
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. VT Engine cuts out while driving...
    By EnzyG in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:48 PM
  3. Engine dies while driving
    By drak0 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2009, 04:27 PM
  4. engine dies while driving?
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2008, 12:32 PM
  5. Car died while driving today
    By Freddo_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2006, 05:27 PM
