Results 1 to 7 of 7
Thread: VS transmission will it fit??
    VX II Calais LS1
    Jan 2010
    Lightbulb VS transmission will it fit??
    Hi guys i did a search but could not find the info i need.
    will a 5/95 5HBD fit in place of a 10/96 6HBD there both 13 pin
    only thing i found on search was this
    VR 1994 - 4HDD/V6 - 4HBD/V8 first electronically controlled auto.
    VR II 1995 - 5HDD/V6 - 5HBD/V8 extra solenoid fitted to provide softer "LOCK UP" torque converter clutch apply.
    VS 1996 - 6HDD/V6 - 6HBD/V8 the design of the previously added solenoid was changed and is not backwards compatible with the previous model.
    VS II 1997-7HDD/V6 - 7HBD/V8 basically the same as the 1996 unit except the thread size of the cooler pipe unions was enlarged.
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive never had to buy another transmission and change it over,but from what Ive read on here as long as the transmission electrical connector has the same amount of pins it will fit no worries.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here's a link with a bit of info on the 4L60E - says the oil is a "lifetime fill".....hmmm
    The GM 4L60E Transmission -
    94 VR Statesman
    Aug 2006
    VS calais S2
    May 2010
    should fit, both are 4l60e, e for electronic, what type of car?
    http://www.acdelco.com.au/PDFs/Catal...nsmissions.pdf
    this site contains the information on every transmission holden built, ur one is on there and 4hdd come out of vr 93 floor shift model v6, an the 5hdd is from a VR 95 floor shift v6. no difference, will fit
    VX II Calais LS1
    Jan 2010
    the 5hdd should have a extra solenoid to the 4hdd the 3-2 down shift solenoid, thats what the extra pin is for in the vs 13 pin trans as apposed to the VR 12 pin trans.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
  1. radiator differences 2 transmission lines or 4 transmission lines...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2010, 12:10 PM
  2. Transmission
    By Leebo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2009, 04:53 PM
  3. Replies: 0
    Last Post: 17-11-2008, 01:51 PM
  4. Transmission.
    By tigerpm7 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-09-2008, 07:33 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
