the panel with the side indicators im wondering if its removable at all and what work is involved.
Yes its removable, pop the bonnet and look for the bolts in the top of the panel and find a socket or spanner to suit, depending on what car you will probably have some others at the bottom and behind the door too.
You'll have to remove the bumper bar as well, there is a bolt hidden there.
Don't forget the screws in the wheel arch.
ok sweet, if the dent puller doesnt do the trick ill swap it out for another one.
