Results 1 to 2 of 2
Thread: Strut bar to chasis bush. How to remove?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Strut bar to chasis bush. How to remove?
    How do i remove the existing rubber bush that connects to the front of the strut bar (z bar, castor bar, radius rod)? It seems like it's all one peice of rubber that flanges out on both ends making it seemingly impossible to remove. I've tried levering it with a screw driver but it's just not coming out. Is there a trick to this, short of cutting it to peices?
    vs commodore
    Oct 2009
    Tamworth NSW
    I cut away the rubber at the front of the bush with a serrated knife until its small enough to come out. Use a long screwdriver to lever it out once the rubber is cut down enough.The replacement bushes are usually in 2 pieces so that makes it a lot easier to install the new one.
  1. How do I remove my lower control arm? or pivot bush.
    By VT_sleeper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2009, 06:17 PM
  2. how do you remove the radius arm bush?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-05-2008, 07:19 PM
  3. VN/VP with Patrol Chasis
    By manvr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 05:24 PM
  4. Custom Roll Bars / Strut, Chasis Brace
    By azkwazere in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 12:43 AM
  5. adjustable strut bush`s
    By heat1 in forum Swap / Wanted to Buy / Trade
    Last Post: 23-05-2005, 05:46 PM
