Results 1 to 9 of 9
Thread: wich way do king spings go?
    vn executive s2 v6
    Jun 2008
    Default wich way do king spings go?
    hi im replacing my spring in my live axle vs with king springs, i dont no wich way up they go? one side the coils are tight together and the other end they are farther apart. any advise? thanx
    vpcalais6's Avatar
    vpcalais6 is offline F#%ING [P] PLATER
    V6 manual vp Calais
    Sep 2007
    central coast
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Look on the springs, it should say "Top" on the top end, unless the printing has worn off, i could'nt tell you mate, i can't remember.
    Quote Originally Posted by peckzz View Post
    also with this fuel thing, i had a old magna 4 cylinder 2.6 litre, and it wouldnt pull a burnout unless it was running 98 premium, so explain that 1?
    vn executive s2 v6
    Jun 2008
    vs commodore
    Oct 2009
    Tamworth NSW
    The flatter end of the spring goes to the top (body) and has the round rubber ring fitted over the mount on the body.The open end goes to the bottom control arm and also has a rubber seat fitted also but is different from the top one and is moulded to fit in the control arm.Make sure the end of the spring is hard against the tab in the spring seat on the lower arm.
    vs commodore
    Oct 2009
    Tamworth NSW
    Just checked it out in a VS gregorys workshop manual.The spring tapers off smaller at one end.This end goes to the top (body).
    vn executive s2 v6
    Jun 2008
    vs commodore
    Oct 2009
    Tamworth NSW
    Yes, Ive worded that wrong saying flatter(the top end of the spring is sort of flat to take the rubber insert that goes between the spring and the body. I should have said its the smaller tighter coils that go to the body. vpcalais6 has told you the wrong way in his post above.
    vn executive s2 v6
    Jun 2008
    hay thanx for clearing that up for me, iv installed them upsidedown, il swap them in the weekend, cheers
  1. Wich sub for box under tray. vs ute
    By MADDNE33 in forum Car Audio
    Last Post: 06-02-2010, 09:44 PM
  2. vs cut spings-lowered
    By cmesk8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 04:54 PM
  3. King spings... camber, tyre wear.. HELP
    By bernie85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2008, 09:56 PM
  4. wich colour turbo badge?
    By cxcxcxvcvcvc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-02-2007, 10:10 PM
  5. how to change spings in vr commodore?
    By madvrcom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2006, 03:24 PM
