Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: stock Vr V6 Acclaim (1994), need advise on upgrades & mods
    VR Acclaim 3.8L
    Dec 2009
    Default stock Vr V6 Acclaim (1994), need advise on upgrades & mods
    Ive got a stock Vr V6 Acclaim (1994), need advise on upgrades & mods
    Now just recently iv put in a 4 pin LSD, and 3:4:5 gear ratio ,and chucked in a speedo corrector...
    Also i removed my stock memcal and put in a performance chip stage III from ebay, is this the right way to put it in? plus i cant feel a difference with the chip
    Because i have done the chip, gears ,and diff, DO i need to re-tune/map/dyno my ECU to get better performance???
    I want to get abit more extra cheap performance ,and i hear that inserting a K & N air-pod or high flow filter in my airbox will be good or Which Cold air Intake system is good?.. which option would be better? I want good cold air to enter my engine ,whats my best option?
    Which injectors are bigger the VN OR VR? Or should i just reco mine..is it worth to reco them?
    If i tighten my accelerator cable abit, will this benefit me in anyway?
    VR Acclaim 3.8L
    Dec 2009
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    i would go for the enclosed pod setup mace have to offer as far as CAI go's. as for the accelorator cable i doubt it unless its very loose and the butterfly doesnt open properly. Most of the chips of ebay are a gimic.
    stop droolin
    VR Acclaim 3.8L
    Dec 2009
    VR Brolina 3.8 Turbo
    Aug 2008
    Wellington, New Zealand
    The whole stage thing is really a myth, Just used to make the chip look interesting. If you want a proper one, PM Delcowizzid and ask him kindly for him to tailor make you one.
    The injectors are the same size, and even if one was bigger you need to do some pretty heavy work on your motor to need even slightly larger ones. Enclosed pod's are great, and can be cheaper than buying a K&N Panel. The cold air intakes that go over your radiator do quite the opposite, and heat up the air instead.
    R.I.P dynoryder
    VL
    May 2009
    K&n air panel filter, extractors, exhaust. Don't worry about anything else unless you wanna get serious which means $$$$
    - --FS - SI VL Calais Turbo (no Motor) Good Project -- -
    RALLIART Magna
    Krabbyball Champion!
    Sep 2008
    Cairns
    G'day mate, get an enclosed pod filter CAI (MACE Engineering)......2.5in exhaust, straight through with extractors (redback are good and produce a nice note).....high flow cat (not really necessary but i got one) and a memcal from Greenfoam or Delcowizzid (this will make the one you bought look like the junk it probably is --- you will defiantly notice a diffierence with one of these tunes)
    All that, with the LSD and diff gears you already have, will have the VR going a lot better than stock!
    You can do some 'car friendly stuff' too ... like new plugs (NGK iriduim -- no power adder but you wont have to change them for some time), leads (8.8mm topgun or eagle) and good quality fluids.
    computer is busted...no internet service
    VR Acclaim 3.8L
    Dec 2009
    whats an enclosed pod filter, where the pod goes inside the airbox?? please explain
    VR Acclaim 3.8L
    Dec 2009
    VS exec S2
    Mar 2009
    its where ur air box is enclosed/attached behind your headlight to stop hot air from the engine entering. Yes a pod is usually enclosed in there. This is in my opinion the most effective way of getting cold air legally
    tada
    stop droolin
    VS executive
    Jun 2009
    VR Acclaim 3.8L
    Dec 2009
    well i just got a vs v6 supercharge CAI ,And im about to put a K & N panel filter, is this as good as the enclosed method? whats better?
    VS exec S2
    Mar 2009
    vr acclaim 3.8ltr
    Sep 2008
    victoria
    I think with some high ratio roller rockers, exhaust, extractors and the CAI you'd be going good. With the tune I'd PM Delco Wizzard on here.
  15. #15
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
  16. #16
    VR Acclaim 3.8L
    Dec 2009
  17. #17
    Jan 2008
    For The Win. And they will set you back around AU$800 + shipping. They are easy enough to fit yourself with a little mechanical knowledge.
    A little advice though, If you dont feel comfortible picking up tools to work on a car yourself, then modifying cars is not for you. Paying for other people to do mods for you is rediculously expensive. On my cars, the only things I ever pay someone else to do is glass fitting and tuning - everything else I do with my own hands, so I know its done right (or atleast how I think it should be).
    Things like precise machine work are an exception to this rule, obviously.
  18. #18
    VR Acclaim 3.8L
    Dec 2009
    So Andrew do recommend vs v6 supercharge cai with pod enclosed or k & n panel filter?
  19. #19
    Jan 2008
    I dont know, I dont use either. I cut a hole in the bottom of my air box, through my guard and I have a big pipe drawing air from behind the bumper. Works pretty well, but not for everyone. I can weld a patch in and put it back to factory if need be.
  20. #20
    VR Acclaim 3.8L
    Dec 2009
    hey guys i want to get a video on a vr or vy v6 with pacemaker extractors and sports exhaust 2.5 inch, idling or driving, i want to hear how it sounds, got any links?
  21. #21
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    i like the pod filter from mace engineering..good idea..i got the ss induction and a BCM filter and havnt noticed a huge difference and think if u were to put any air intake in tat this idea seems the best... not sure how to answer ur video question type it into youtube
  22. #22
    VR Acclaim 3.8L
    Dec 2009
  23. #23
    Black 03 VY Storm UTE
    May 2010
    Bundaberg, QLD
    hey i got a auto vs ute with 83000ks wen i bought it it had pacemaker extractors on it, n it went good then. In the last 6 months ive put on a 2.5" lukey cat back exhaust without rear muffler. sounds sic n gained a fairbit of power,cost me $350 i think, then bought a high flow k&n panel filter, and it did HEAPS ay. def worth the 80 bucks. That the only mods far as i no, but it goes so good now really punchy, beat a vr ss the other nite, n a turbo 6 vn ute,to 80. if u gunna do anythin i wud recomend these anyday!
    as for a link for sound of one this is one i found on you tube sounds like mine. YouTube - V6 VS UTE with exhaust and extractors
  24. #24
    VL
    May 2009
    there is no way u beat a vr ss mate, did you ever think he just didnt go as hard as you at the time?
  25. #25
    VL
    May 2009
    go 1/4 mile head to head, it wont even be close
  1. 1994 VR Acclaim w/ L67 + T5
    By wamboin23 in forum VR - VS
    Last Post: 23-06-2011, 09:10 PM
  2. my 1994 vr acclaim
    By toto101 in forum VR - VS
    Last Post: 16-08-2009, 01:42 PM
  3. 1994 vr ute upgrades
    By brute-vr-ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2009, 11:08 AM
  4. [NSW] 1994 VR V6 Acclaim
    By bittsa in forum Vehicles For Sale
    Last Post: 15-12-2008, 01:43 PM
  5. o.0 -1994 Vr Acclaim
    By iRiot in forum VR - VS
    Last Post: 19-10-2008, 11:09 PM
Tags for this Thread
