Results 1 to 5 of 5
Thread: Dash upgrade
    Vs Equipe
    Oct 2006
    Default Dash upgrade
    hey all
    i have a standard executive dash and i would like to upgrade to a calais dash (lv3) i believe , the only part of te upgrade im a little bit confused about is i have standard aircon not climate control is this a problem will my air con still work normally ?
    VS Ute & VZ SV6 Sedan
    Nov 2007
    i upgraded my S1 standard dash to a level 2 dash with a tacho .
    i think level 3 requires the body control module to suit . the a/c shud be good . not sure about that tho .
    most favourite JC post - I'll be head'n to the wrecker tomorrow for a new one.
    VS Berlina 3.8
    Dec 2008
    Never heard this one before. I doubt your air conditioning will have anything to do with your dash cluster.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The L3 dash loom has climate contol - not the A/c unit like the Exec's. So when you get the L3 cluster and a L3 loom you need to strip the plugs out of the L3 loom and graft into your L2 loom.
    No BCM is involved at all. - just a patch loom to make the trip computer work.
    and 3 Dangerous non ABS VN's
    94 VR Executive & 99 VT XU8
    Mar 2005
    Melb
    check out the 'tripin' thread. (it has everything you need to know and more)
    94 VR V6 - No ABS & NO IRS... a true mans steed and a 99 VT XU8 for good measure.
  1. Need HELP! need someone to do my Lvl 3 dash upgrade
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2009, 12:51 PM
  2. dash upgrade
    By achilds_1999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2007, 11:19 PM
  3. Dash upgrade?
    By Cav in forum General Discussion
    Last Post: 01-11-2006, 08:43 AM
  4. VP dash upgrade??
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2006, 08:08 PM
  5. VY II Upgrade Dash
    By RacerX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-03-2005, 09:06 PM
