KHRL 46 SSSL King springs, can someone tell me if these will suit a vs v6 irs?
- --FS - SI VL Calais Turbo (no Motor) Good Project -- -
if you mean KHRL 46 SSL they are an ultralow springs and yes they will fit a vs irs
no i meam SSSL
Are they shaped like a beehive?
sssl are ultra low, ssl are super super low
never made a sssl for an irs commodore http://www.kingsprings.com.au/catalo...e%20040203.pdf
There not in the catalogue but i'm about 95% positive they exist, as for the original question, yes they will suit vs v6 with irs but will be very very low
SSSL Are Ultras And yes they should fit as i have them in my Stato.
have a pic of the vs commodore they were in, it's just on the rims on 19z
It should be known that the amount of "S's" in the part number does not indicate if they are "super low" or "ultra low" or their height, it is simply a catalogue number. My KHRL 46 SL springs turn into ultra low springs when the are put in a VN/VP, but are super low when they are used in my VS.
Have a look at this quote from Lowest springs for a vr commodore
With GSL RallySport also confirming this in the post under it.
So in that case how do I work out how low they will be in my vr?
you use the catalog...
RJK is 100% correct!
Only today we sold springs for an FPV where SSL is only 'low'!
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
cant acsess the catalog on my computer for some reason!
can any one supply the code then which will give me the lowest available (looking for a SSSL or SSL look)
There are 2 catalogs. I believe, one for road use and one for "show/track" use. Only the road one is available online. You will probably have to go to autopro/repco etc as they will have the other catalog.
nah mate repco is where i work and we only have that catalouge. Had a chat to Kingsorings today the lowest they make for a vs irs KHRL 46 SSL. Hope this helps
quote from catalog
NOTE: MANY SUPER LOW OPTIONS EXIST THAT ARE NOT LISTED. PLEASE ENQUIRE
maybe email them?
Mines meant to have -127's but had -46's and now has -46sssl's, they don't list the -46 as a spring for the ute but there is a pic of a ute on the website quoted as having =46's in it. I'd imagine the sssl's would physically fit but they may be quite low.
google is your friend
thasnks for the comments guys, my car is alreaddy lowered front sit a bit lower then the above picture, and rear sits just higher. but i can tell that the rears have been replaced, btw i want my rear about 1/2" lover then that...???
Do you want to be able to drive the car?
ive heard jb camira springs fit......
camira springs fit sits a fair lot lower than ultras do and actaully give quite a good ride. ive got a pic of a mates vr with them in it
nah i mean not too bouncy or too stiff but your right speed humps can be a challange along with steep driveways.
just to bring this up again in a vr commodore irs rear springs KHRL46SSL Will sit lower then springs KHRL46SSSL?
and for those who know suspension perhaps you can help me out with this problem
Rear Shocks To Suit Springs...
