Results 1 to 10 of 10
Thread: vs temp sender
    Vs SS
    Jul 2009
    Default vs temp sender
    can any one help me 2 find the temp sender 4 my 5liter or have a pic
    VX II Calais LS1
    Jan 2010
    its on the front of the inlet manifold under the throttle body, theres 2 sensors there. One is the temp sender to the dash temp gauge and the other the temp sensor for the ecu, left one is dash right is ecu as you stand infront. You can get them both out with out taking the TB off.
    Vs SS
    Jul 2009
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Quote Originally Posted by DvS_Ls1 View Post
    tb ??? kind of new 2 this sorry mate
    TB is Throttle Body.
    Vs SS
    Jul 2009
    BoNeZ-01's Avatar
    Mar 2010
    Yeah, I had a look in my Max Ellory's VR/VS book, the pics aren't very good, but, best I can work out, as 'bandit10' said, the sensors are kind of behind(when standing in front of the car), and under the throttle body.
    I'f you stand about the left headlight, and look down in behind the throttle body, near the area of the oil cap on the rocker cover, they are hiding down in there between the fuel rail, and the rocker cover, in the lower half of the intake manifold.
    Best I can describe without access to an actual 5lt VS for pics.. lol
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    Vs SS
    Jul 2009
    thankz been haven a prick of a time with my car everything going wrong with it
    BoNeZ-01's Avatar
    Mar 2010
    lol yeah, tell mi bout it, same with me and my two, must just be the age of them I guess? nothins built to last these days.. :/
    Vr Berlina 195i
    Apr 2009
    west side
    easiest way to get to it i found remove the radiator fan and shroud, engine covers and you will see a loom that runs on top of the water pump look behind there the green single wire is the temp sensor for the dash it slides into like a O terminal, thats on the left side and on the right is the one going to the ecu. Mine used to play up on the dash until i removed the clip and you can bend the connector so it slides in nice and tight. you will understand once you get it off
    Vs SS
    Jul 2009
    yea i found it and i found out why not working stupid clip wasnt on the bloody thing lol drrrrrr why didnt i check that 1st dosent matter thankz 4 ur help everone
  1. temp sender
    By arex7 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2009, 11:40 PM
  2. ECU Temp sender - VR, VN the same??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2009, 12:48 AM
  3. 253 temp sender
    By yobbo88 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2008, 06:55 AM
  4. temp sender
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 10:00 AM
  5. Help-temp sender
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 12-09-2005, 01:34 PM
