does anyone wat glue or adhesive to use when puttin new door seals on a vs
if you mean the ones around the door opening that are stuck to the trim these used to come off my VN all the time and I used Bostik contact adhesive. If you clean both surfaces well and apply in a thin layer to each side it will last a long time. I thought that new these rubbers came with the moulding attached?
Clear Silicon you can get from Bunnings will do the job too.
Make sure you don't put too much on and clean up immediately after or it will look crap!
i used proper weatherseal adhesive, forget what brand it was but i got it from supershit. great stuff but very messy
WTB VR/VS FACTORY HEADUNIT BRACKETS PM MEOriginally Posted by MY-42-VT
