as it says i have squashed crimped destroyed my front aircon lines.
(Circled in the pic)
do i need to replace the whole line or can u cut and rejoin the line in some way
Maybe a flexi line or sumthin?
cheers
hayden
Im probly wrong so dont listen to me
a competent repairer MAY be able to salvage it, but most will just replace the condensor lines.
its quicker and therefore cheaper.
from your photo though it looks like your pointing to the small radiator at the front??
that is your gearbox oil cooler, not the AC.
simply replace the rubber hoses with new ones.
and dont use radiator/heater hose, use high pressure rubber hoses as the cooler can reach pressures of 150psi plus.
yeah thanks, yup i kniow thats the transmission cooler, i ment wots behind it, yeah i was guan get dad to nick sum hydrolic lines from work for it, the aircon blokes want $600 and another wants $800
full replacment of everything.
i will change the lines myself, and regass and see how it goes, hows does it get regassed?threw the core or up in the cylidner bit in engine bay >?
You sure thats not a tranny cooler? I have never seen a/c rubber lines held with hose clamps like your picture.
