Results 1 to 4 of 4
Thread: VR abs into Vs commodore
    VY Senator 5.7
    Jan 2009
    Default VR abs into Vs commodore
    hi every one need little help here plz i have a VS commodore i was wandaring if ABS off VR will fit to VS commodore non abs live axle and other thing how hard it is to put cruise control as well.
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    The Unit looks different so I would think that it is slightly different
    probably the safest way wud be to swap the whole engine bay loom with one from a VR that had abs, same deal with CC
    my 2c
    VX II Calais LS1
    Jan 2010
    you will have to swap your rear diff over with one that has ABS as the sensors are in the housing and the actual axles have the toothed part that the sensors read, you will have to swap your front hubs over aswell to the ABS ones and im sure there will be a heap of wiring for it to.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    ..... also, you will need the front ABS hubs to match the live axle ABS as there are two types of ABS front hubs. Different number of sensor teeth between IRS and live axle.
    Big job. Maye sell your and buy a car that has ABS and cruise.
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Replies: 6
    Last Post: 17-05-2009, 10:57 PM
  3. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
