Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: fitting cruise control help
    VX II Calais LS1
    Jan 2010
    Default fitting cruise control help
    ive been trying to fit factory cruise control to my car, all the wiring was already there for it, the plug was in the engine bay loom and the plug was under the steering wheel for the control stalk.
    I have fitted the cruise control module and a brand new control stalk it turns on and the dash light lights up so say it is on but it will not set/activate what am i doing wrong?? any ideas?? i have plugged in the relay that was missing in the fuse box.
    I thought with all the wiring already being there it would just be a case of plug it all in.
    any ideas would be great thanks.
    ethann's Avatar
    ethann is offline Low And Luxurious!
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Dec 2009
    Newcastle, NSW.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by ethann View Post
    Just out of curiosity, You have connected the cable to the throttle body right?
    lol yes mate. its all pluged it and connected as it should be, just wont activate
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    brake switches installed and adjusted? there are one new one and one wiring connection to your original one
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VX II Calais LS1
    Jan 2010
    the brake switch thats on there already has 4 wires going to it, and i was told this is the correct brake switch for cruise???
    How do i adjust it??
    Nov 2003
    northside brisbane
    brake switch installed wired and adjusted?
    VX II Calais LS1
    Jan 2010
    ive not done anything with the brake switch, i was told it already had the correct brake switch on there for cruise to work?? how do i check it is the correct one and how do i adjust?
    Nov 2003
    northside brisbane
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by nathanwright View Post
    do you know how to tell if your car has the wiring there?
    yes it has the wiring there mate, ive already connected up the control stalk and the module
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by markovr View Post
    here is a quick guide to how to adjust the new switch
    cant see any link in your post???
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by bandit10 View Post
    reckon you could post a photo of what it looks like? id like to see if mine has it.
    Nov 2003
    northside brisbane
    check my post above..sorry must have stuffed something up before.
    VX II Calais LS1
    Jan 2010
    thanks for that mate, by the looks of that diagram i have the electrical release switch missing.
    nathanwright - mine had the plug taped up in the wiring loom on the passenger side, might be different to yours tho as mine is a VS 5ltr
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
  16. #16
    VX II Calais LS1
    Jan 2010
    ok cool so it was taped up and hidden? is yours an exec?
    no it a SS, it was taped but not really hidden its a large plug you will be able to see it if its there.
    I had to un-tape it to get the wiring long enough to reach the module position, but the plug was visible whilst it was still taped.
  17. #17
    Nov 2003
    northside brisbane
    its a standard early vn/p brake switch... you will find in most wrecks make sure you get the circular clip it sits in when you get the switch
  18. #18
    VX II Calais LS1
    Jan 2010
    will do, thanks for your help.
  19. #19
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
  20. #20
    VX II Calais LS1
    Jan 2010
  21. #21
    VX II Calais LS1
    Jan 2010
    The cruise plug is about 35mm wide 20mm deep and has about 5 wires going to it mate. Doesnt look like its in your loom from that pic.
  22. #22
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
  23. #23
    vs commodore
    Oct 2009
    Tamworth NSW
    There needs to be 2 brake switches installed.One is a backup in case the other one fails to cancel the cruise control for any reason.
  24. #24
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Re the second brake switch - it can be "temporarily" bypassed by simply connecting the two wires in the (spare plug) that goes to the CC second brake switch so that it makes a circuit. Locate the plug - it will be close to the 'normal' brake switch and has 2 cables - a pink cable and a brown cable. Bridge the connector to simulate the brake switch. This is just a temporary test procedure to make the CC think it has the second brake switch installed.!!!!
  25. #25
    VX II Calais LS1
    Jan 2010
    thanks for the extra info, ill give that a try just until i can get hold of a release switch.
  1. fitting cruise control - issues
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2008, 06:27 PM
  2. Fitting Cruise Control To VS V6
    By LJS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 07:27 PM
  3. Cruise Control fitting to VY
    By kricket in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-10-2006, 07:55 PM
  4. Fitting Cruise Control to VP
    By bubbles2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2005, 06:14 PM
  5. Fitting Cruise Control on 91' VN
    By dcherry in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2004, 08:22 PM
