Results 1 to 18 of 18
Thread: VS couple of questions.
    vs commodore
    Oct 2009
    Tamworth NSW
    Default VS couple of questions.
    Can someone tell me if the VS level 2 dash beeps (similar to the handbrake/low fuel warnings) when the engine temp gauge goes up to the hot position? (engine overheat condition).And also did the VS have a power radio aerial fitted to all models?
    Thankyou.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My VS Exec came out with a standard aerial....dunno about the overheat warning (fortunately)
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Should beep when overheating.
    Beeps
    Stolen from 'beepping' post. Haha
    EDIT: you said level2! Not sure....earth out sender and see???
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    VS Commodore 3.8L
    Feb 2010
    i dunno about the series 2, but my exec beeped when it got too hot, cant describe the sound, kinda rises in pitch (do do do do)
    bought the car for $200 - burnout car
    liked to overheat =]
    VS commadore V6
    Mar 2007
    When I bought my commodore [ series 1 ] it was 12 months old & had the power radio aerial already fitted, water pump went on her a while back causing it over heat but got no beeping sounds when it happened.
    vs commodore
    Mar 2010
    I have a series one vs 1995 and it doesnt beep when it gets hot either it might only came out on series 2 .
    vs commodore
    Oct 2009
    Tamworth NSW
    I earthed the temp sender wire out and there is no beep when the gauge goes to hot.The gauge goes way over the "H".About half again on the scale.The beeper works when the handbrake is on and the car moves or when it gets low on fuel so it definitely works.It just doesn't beep for engine temp.It should though,it would be better than just a gauge.Maybe the later ones do according to the answers I recieved on here.The reason I asked the about the aerial ,most VS's Ive seen have a power aerial.I thought mine might be broken but I think if it had a power aerial it would have switches to move the aerial up and down.Mine does not have these anywhere.Where would the up/down switches normally go anyway,can someone tell me that please,Ive never really taken any notice before when in op's VS's
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    If it doesn't have up/down switches then it has been fitted with an aftermarket unit. The up/down switches go in the space just below the head unit - along side the engine immobiliser warning light (if not fitted with climate control).
    vs commodore
    Oct 2009
    Tamworth NSW
    Thanks to everyone for the answers and info.Mine definitely has no up/down switch there,so no power aerial,(not that I really care).I just thought it might have one, just not working.Thanks again.
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I forgot to mention that the buttons for the higher spec models are actually built into the head unit. That means that if the head unit has been replaced then you have lost the ability to raise or lower the antenna.
    vs commodore
    Oct 2009
    Tamworth NSW
    Mine still has the original radio/cassette unit.Theres nothing on it either about the aerial up/down,its only an executive, so Id say it never had one fitted as an option,but thanks for the info.Cheers.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Ive got a feeling you need a LUX or higher spec BCM to get power antenna.
    vs commodore
    Oct 2009
    Tamworth NSW
    According to the VS gregorys workshop manual if the car is fitted with a low BCM,and it has a power aerial,it doesnt use the BCM to control the aerial,it has a power aerial module instead to control it.The med ,hi and lux use the BCM to control the power aerial though.Cheers mate.Thanks.
  15. #15
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    i have a vr acclaim and it has a power aerial, how ever the only control i have over it is when the factory radio/cassette unit is powered on the aerial rises and falls when the power is switched off.
  16. #16
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Here Mate you can see the up and down buttons under the radio. The computer has memory so it keeps the same aerial height you set.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  17. #17
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    my s2 vr exec has the hot beep, found that a few times sadly
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
  18. #18
    VS_Pete_1's Avatar
    Dec 2007
    Quote Originally Posted by TheForgotten View Post
    I had that once the air wasn`t bleed out properly when I first got the car.
    All good now. (level 3 I got)
  1. couple of 304 questions
    By pow3rslave in forum General
    Last Post: 20-06-2009, 02:44 PM
  2. Just a couple of VS questions
    By The_Lexman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2009, 07:24 PM
  3. a couple of vs ute questions
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2008, 08:22 PM
  4. Couple of questions - regarding my VC
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-01-2007, 05:35 PM
  5. A couple of questions.
    By 97 SEN in forum Car Audio
    Last Post: 14-07-2006, 01:18 PM
