Results 1 to 19 of 19
Thread: Door Lock Problem - VR
    2001 VXII SS Commodore
    Nov 2009
    Default Door Lock Problem - VR
    Hi,
    My friend just bought a VR and there is a problem with the door locks.
    When you unlock the car, using either the button or the key all the door locks pop up, but then you go to lock it via either method only the front doors and boot lock. The back 2 locks look like they are trying to lock (they shudder) but nothing happens.
    Any idea's how I can fix this for my mate?
    Cheers guys,
    Adz
    vs commodore
    Oct 2009
    Tamworth NSW
    It might be a faulty BCM (Body Control Module) which controls the central locking amongst other things.If there is an error logged in the BCM you can access that by seeing someone with a scantool that can access the BCM.It is most probably a faulty door switch or something else though..If it is the BCM and you get another one from a wrecked car etc,you will need the key from that same car.Its a security thing.The keys security number has to match the BCM security number..
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    Ouch! I have a 'similar' central locking issue in my VS, AND a sticky ignition barrel, not liking the sound of buying a new BCM, key remote, and barrel.. $$$ :/
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
    Nov 2009
    damn i thought it might have just needed a bit of CRC or a new latch or something like that =o The key also sticks when you are trying to open the door using it.
    Is there any contacts or anything like that which could be dirty and stopping them from engaging? (I've never worked on a VR, only an AU (ewww) and my SS.
    Thanks again!
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Before going out and getting a new BCM, rip the door trims off and lube everything. My back drivers side lock wouldn't go down, after a squirt of silicon spray it was right as rain.
    BoNeZ-01's Avatar
    Mar 2010
    Will give that a try. My remote unlocks the rear doors only, and locks the drivers side rear door only, the rest I have to do by hand.. annoying! lol
    vs commodore
    Oct 2009
    Tamworth NSW
    When I first got my VS the rear doors wouldnt lock/unlock with the central locking.I pulled the trims off and the wiring connectors had come apart.Apparently its fairly common for this to happen.(although if the lock button actually trys to move(shudder) when you try to lock/unlock it,then it is not going to be the wiring connectors).Also when I mention the BCM before in my other post I didnt mean to just go and replace the BCM, thoroughly check everything else out first.Or see if theres any error codes logged,which might point to what the actual problem is.
    BoNeZ-01's Avatar
    Mar 2010
    Ok, Kewl, so checking BCM codes, are they stored in the BCM, but also logged/linked to the ECU, to be read the same way as reading ECU?
    Or are BCM codes read seperatly from the ECU?
    vs commodore
    Oct 2009
    Tamworth NSW
    They are read seperately from the ECU codes.You need to see someone with a scantool (holden) that can access the BCM to check these codes.
    BoNeZ-01's Avatar
    Mar 2010
    Ahh.. I see, is that scan tool one of those Tech-2's(I think it's called) I've read about in here?
    vs commodore
    Oct 2009
    Tamworth NSW
    Tech 1 is used up to 1995 VS models,after 95(late VS & VT onwards) they use a Tech 2.
    BoNeZ-01's Avatar
    Mar 2010
    Ohh ok, that's handy to know, thanx.
    Nov 2009
    ok so after going out at arvo brew and taking a look, the back door locks pop up, which makes me think its not the BCM or lube, but they won't go back down ????
    its got me stuffed....
    shed any light??? *Crosses fingers*
    Nov 2009
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by adz_1983 View Post
    and in answer to the question, no a scantool is not a tech-1/2
    What?You had better tell everyone just what a scantool is then if a Tech 1 or Tech 2 arent. Vetronix (the makers of the Tech 1) call it a scantool in their user manuals.Are you gonna say you know better and that they are wrong and dont know what they are saying or selling.
  16. #16
    VS 5 Litre BT1
    Jul 2006
    Sometimes the orange tab on the button can catch just enough to stop it going down to the lock position. Explains the shudder and why it will always unlock but not always lock.
    I believe if you get the button off and give the bottom of the orange tab a light sand it should fix it.
    My right rear door will lock sometimes.....sometimes not..... I just need to extract the digit and do something about it !
  17. #17
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    my back drive door dose the same thing i just taped the lock down cause i can only have 1 passenger so its not a real problem for me
  18. #18
    Nov 2009
    Quote Originally Posted by Brett_jjj View Post
    Nope I wouldn't say I know better, purely for the fact i don't, and i don't make out I do.
    I just know that my mate is a mechanic (not the best one but he'll do), he has a scantool, and I asked him if it was a tech 2, as i wanted something done with a tech 2, he said hell no, see Holden, they are the only people who have access to tech 2s. Just what he told me, passing on that info.
    Holden make Astra's and Vectra's, are they the same? They're made by the same company so they must be the same? they're both cars after all!
    There are many kinds of scan tools available, they just don't have the same features as the tech 1/2s
    so sorry to have offended you lol not my intention
  19. #19
    vs commodore
    Oct 2009
    Tamworth NSW
    You havent offended me at all.I was just wondering why you would say that to someone.Also theres many scantools available including the TECH1 and TECH2.
  1. Vn Door Lock Problem
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2009, 10:47 PM
  2. problem with door lock
    By azz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2009, 02:05 PM
  3. Door lock problem
    By Secki in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2006, 11:59 AM
  4. Door Lock Problem
    By JTW008 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2006, 08:21 PM
  5. Door lock problem.
    By nomad in forum Electrical Wiring / Questions
    Last Post: 19-01-2006, 10:10 AM
