Results 1 to 6 of 6
Thread: Removing door trim
    VS Executive wagon
    Mar 2010
    Default Removing door trim
    What is the proper way to remove the door trim on a 94' VR?
    There are 3 screws on the bottom of the pod , but other than that what else do you have to do?
    Also, the windows are manual - so will the window handle be a problem when removing the trim?
    vs commodore
    Oct 2009
    Tamworth NSW
    Remove the screws from the door handle,remove the little wire clip that holds the window winder on,-its in behind the winder handle.Theres screws near the door air vent,remove the vent.Theres an orange clip on the door lock button,remove it,it just clips on/off,then remove the lock button.And carefully unclip the door trim from around the door.Use a screwdriver with a cloth over it so it doesnt damage or scratch anything.
    VX II Calais LS1
    Jan 2010
    remove the vents on the front edge of the door trim, there are 3 screws behind there, you need to pull the vents out of the housing to get am them, pull the center out of the door handle that you close the door with theirs 2 screws behind there, pull the door lock pin off by unclipping the red tab you can see when its in the unlocked position there is 1 screw behind there, 3 long screws at the bottom then pull as their is a few clips around the edge that hole it in place.
    The window winder needs to be removed by pulling the clip from the back of it, if you dont have the correct tool it can be a little fiddly to get out use 2 small screw drivers and you should get it.
    edit: brett beat me to it!!
    Holden VS S Commodore
    Sep 2009
    did it this morning, what both the fellas said is spot on but becareful when you take the grab handles off cos my screws fell inside the door which is a hassle!
    Quote Originally Posted by Jesterarts View Post
    With that logic, I want a cash incentive for every day I don't punch someone in the face.
    91 VN V6
    Feb 2010
    other than the vents on the door would this be the same for a VN-VP? and i cant see the orange clip
    vs commodore
    Oct 2009
    Tamworth NSW
    Its the orange clip thats visible when the interior door locks are open or pulled up.Its also used as a visual aid to indicate that the door locks are in the unlocked position.VN/VP are the same as VR/VS.
  1. Removing VY/VZ door trim
    By Lumps of cheese in forum Holden Commodore How-To's
    Last Post: 01-01-2012, 11:33 PM
  2. Removing VT/VX door trim
    By Julie in forum Holden Commodore How-To's
    Last Post: 13-10-2011, 09:35 PM
  3. Removing Ve door trim
    By IGNITIONSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-04-2010, 01:38 PM
  4. Removing the door trim
    By f1tzy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-09-2007, 05:04 PM
  5. Removing door trim
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2006, 12:55 PM
