Results 1 to 7 of 7
Thread: Dash & tail llights not work or parkers but main and high do, help
    VR Statesman & BA XT
    Apr 2010
    Unhappy Dash & tail llights not work or parkers but main and high do, help
    hi all
    just got a vr statesman and when i go to turn on the headlights to parkers, they dont turn on neither do the taillights or dash lights..... yet the normal head lights work and so does the high beam....
    i checked fuses there fine and if i run direct power to the fuse under dash parkers/ tail lights/dash work but nothing when i turn the switch.... now could it be the head light switch....
    or should i be checking wires behind the fuse box
    cheers in advance for any ideas or advice
    christel & paul
    vs commodore
    Oct 2009
    Tamworth NSW
    There are relays under the dash near the fuses that are for the park lamps and the rear window demister.Id try swapping it for the other one (rear demister) ,the park lamp one might be cactus..They are the smaller type of relay,not the bigger square ones.And it has a blue stripe on it.It has 4 pins.There are similar relays with a gold stripe,these cant be used there as they have 5 pins.The airbag relay is under there,dont remove it and turn the ignition key on.It will set an error in the SRS system and the SRS light on the dash will be on.You will have to pay to get it turned off again.Im not sure which relay the SRS one is.They are all marked under there on a sticker on the panel anyway.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Just try replacing the fuse as they may be stuffed but look ok.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    vx s pack II
    Jan 2010
    aLKIDA
    Sounds like the switch mate.
    But check all the relevant fuses.
    If the fuses are fine check the relays see if the signal is getting sent down to the relay from the switch to energize the relay. There are some relays under the dash and the headlight relays under the bonet.
    If there is no signal then it will be the switch. Just check for power with the test light.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Are you checking fuses with a test light?
    Apr 2010
    checked all fuses , when we put direct power to under dash fuse area they all worked using the switch, i even replaced switch with new one, still no go.... we found some burnt out wires in engine bay near drivers headlight and replaced the plug and wires and we now have high beam both sides too, just still no dash lights or rear lights.. the break light and revers work just not standard rear lights or dash lights, we did check every relay and there all fine,, i told hubby it has to be a faulty wire from the switch to the fuse box under dash as like i said we get it working when we run direct power to it in fuse box...... if anyone has a wiring loom diagram that would really help.. it is for a vr v8 stato.. if can scan on computer then can email to me at
    forevr69@bigpond.net.au
    cheers for all the advice guys
    christel
  1. HELP!!! NEED 2 NO THIS! bout parkers and main light
    By kizza50 in forum Electrical Wiring / Questions
    Last Post: 21-12-2009, 09:32 PM
  2. High Beam/Parkers work, Low beam doesn't?
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2009, 05:15 PM
  3. Parkers and Tail Lights stuck on!! (Liberty)
    By 1991_Vn2nV in forum General
    Last Post: 31-10-2008, 12:05 AM
  4. parkers don't work
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2005, 03:12 PM
  5. MONARO STYLE llights for a VN berlina
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2005, 02:33 AM
