Results 1 to 13 of 13
Thread: Rear Window Demister
    VXHBD6's Avatar
    VXHBD6 is offline Get Hozed!!!
    VR Executive
    Jail Escaper Champion!
    Nov 2009
    South Australia
    Default Rear Window Demister
    Hey guys,
    First time the rear window has fogged up bad enough to use the demister, but had some torubles - it didnt work.
    Once I was back home I took off the passenger side bit that sticks to the window and gave it a bit of a clean over and then held it back on its place on the window with the demister going and about the 3 middle bars demisted but the rest didn't work.
    Has anyone else had this problem? What was it like to fix?
    Cheers,
    Nick
    Check It Out
    My 93' VR Executive
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Yeah but its kinda something I'd like to get working, better then wiping it every morning with a towel.
    Check It Out
    My 93' VR Executive
    VX II Calais LS1
    Jan 2010
    pretty sure ive seen a "how to" somewhere on here telling you how to test and repair the heated rear screen, good luck finding it with the search function the way it is after the upgrade. lol
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    I've found a few topics on here that explain about the paint that conducts electricity etc..
    Does anyone know if theres much involved in installing a brand new demister? Do you have to replace the back window or not?
    Check It Out
    My 93' VR Executive
    vs commodore
    Oct 2009
    Tamworth NSW
    Theres a conductive clear lacquer you can get to repair the rear demister.You just use a multimeter to find where the break is in the wires on the glass,then put two strips of tape each side of the wire and paint the lacquer over the gap between the two peices of tape to restore the broken connection.Once the tape is removed and the lacquer is dry you can not tell it has been done.This is available from most auto shops.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Ahk sweet.
    I'm pretty good with a multimeter but whats the best way to test for breaks? Just test for continuity along the strip? If they all come up fine (meaning no breaks) what would be next to try?
    Check It Out
    My 93' VR Executive
    vs commodore
    Oct 2009
    Tamworth NSW
    If there are no breaks in the wires on the glass and its not working,Id be checking the fuses and the relay under the dash.Also follow the wiring as best you can from the rear screen and check for any disconnected connectors or breaks in the wiring.The switches can sometimes be faulty.The demister button should have an orange light glowing on it when the demister is turned on.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I had the same problem in my wagon.
    Bugged me so much I fitted a new rear glass. $190 from Holden.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Cheers for the replies guys,
    - Orange demister light goes on fine so that probably rules out the fuse/relay wouldnt it?
    Suppose I will just go over all the wiring and that over the weekend. Worst case I'll just get a new back window $190 aint to bad.
    Check It Out
    My 93' VR Executive
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by <VRCOMMY> View Post
    FYI
    That was for a wagon, plus fitting.
    VXHBD6's Avatar
    VR Executive
    Nov 2009
    South Australia
    Cheers mate
    Hopefully I can manage to get this demister going instead!
    Check It Out
    My 93' VR Executive
  1. Rear demister cause rear window to shatter?
    By gendi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2009, 10:24 AM
  2. Rear window demister
    By OldDog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2008, 09:58 PM
  3. Rear Window Demister
    By Moylance in forum Electrical Wiring / Questions
    Last Post: 11-11-2005, 09:39 AM
  4. Broken Lug, Rear Window Demister ??Fix??
    By markc3012 in forum General
    Last Post: 25-04-2005, 01:07 PM
  5. Rear window demister replacement?
    By aa23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2004, 10:20 PM
