Results 1 to 5 of 5
Thread: Vr ss power window stiches
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Default Vr ss power window stiches
    Hi guys,
    am trying to remove the floor console on a vr ss. All screws / bolts and wiring have been disconnected but i cannot remove the power window switches below the handbrake.
    Have searched the net and forums but can only find forums that relate to a vr ss with power window switches in the floor console that can be disconnected using the connection a couple of centimetres up from the actual power window switch.
    After popping out the power window switches in my vr, the wiring is a continues wire that runs direct to under the dash. No way of disconnecting it.
    Any help would be much appreciated!
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    There's two types of switches. Some have a short loom attached to them and some have a long loom. The short loom type have plugs about 10cm from the switch and then the long loom type (which it sounds like you have) have the plug further along infront of the shifter and under your radio area. Just shine a torch under there and you should see them. There will be two plugs. Hope that helps.
    Aug 2008
    NSW South Coast
    Also, have you removed the plastic shiter surround plastic? This needs to be removed to access the plugs and also to get to the centre console adjusting screws.
    Rusty's Avatar
    Mar 2010
    Queensland
    cheers mate, will check it out,
    have removed all the surrounds and will have a go at finding the cable.
    cheers again for help, saves me tryin to pull apart the dam switch!
    Rusty's Avatar
    Mar 2010
    Queensland
    sorted, thanks heaps for the help guys. My VR has got the long loom hidden under the stereo in the centre console. Glad i had to rip all the interior out anyway!
    Thanks again for the help guys! Mucccccch Appreciated
  1. power window
    By stacey253 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 10:38 PM
  2. [VIC] VP/VN/VR/VS Power Window Kit
    By B3ND3R in forum Parts And Other Items For Sale
    Last Post: 03-07-2009, 10:55 PM
  3. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  4. Power Window Up
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2008, 03:55 PM
  5. vn-vs power window kit
    By winton in forum Parts And Other Items For Sale
    Last Post: 09-12-2007, 11:14 PM
