Results 1 to 6 of 6
Thread: VS ABS Sensor Problem
    Vy commodore
    Mar 2008
    Default VS ABS Sensor Problem
    Hi Guys,
    Did a stupid thing last nite and snapped the ABS sensor wire of my front hub.
    Is this an easy fix any suggestions
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If there is enough lenght in the wires you could try soldering them back together. If not, then you need a new sensor.
    Either way, it should have turned on the ABS warning lamp and logged a fault code. This will need to be cleared after the repairs.
    VS Berlina 95
    Mar 2012
    Mornington
    ive done the same thing, i went down to my local ABS shop and they told me i had to book it in to get it replaced im hoping not, if i find any info on replacing it ill let you know
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The sensor is not easily replaceable as it is part of the hub - normally the hub and sensor are replaced - wreckers have them for about $50 ea and new they range from $150 to $300 depending on country of origin. Not difficult to replace the hub as it is held on with 3 bolts. There are 4 different hubs....non ABS...IRS...non IRS...left and right and you must get the correct one otherwise the ABS will not work.
    VB SL/E
    Dec 2008
    Wrecking yard for wires etc and just buy a new after market hub if needed.
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. vt o2 sensor problem!!!! HELP!!!!!
    By mickymodge4 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2010, 01:45 PM
  3. Map sensor problem
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-01-2007, 05:53 PM
  4. Oxy Sensor Problem
    By some_evil in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2006, 12:23 PM
  5. VR Oxy Sensor Problem
    Last Post: 23-03-2005, 08:03 PM
