Results 1 to 22 of 22
Thread: New Wheels = Problem...Ideas
    ETH4N's Avatar
    ETH4N is offline Project VS
    1995 VS Commo
    Jun 2006
    Central Coast (Watanobbi)
    Default New Wheels = Problem...Ideas
    Hey Guys
    So got my 17" SS Wheels today, put the 1st three on, all sweet, got to the third, and no go.
    Stock wheel off, look at the hub, and there is like a lip (kind of like a spacer, i suppose, but not a spacer...)
    Heres a pic of the HUB, and also the back of the wheel (incase your unsure what it looks like)
    Any ideas??
    Pics:
    VS V8 Berlina Wagon
    Jul 2006
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
    VS V8 Berlina Wagon
    Jul 2006
    if its a second hand car then someone has put a different rotor on, personally (if you can afford it) id get 2 new rotors and put them on
    VT V8 berlina
    Jan 2010
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
    I haven't at the moment, but I will try and get one, does it look familiar?, any easy way to get around this?
    VT V8 berlina
    Jan 2010
    try that one mag one the other side?vt ss wheels fit just about any commy so got me stumped why it not fit even if the hub/disc been changed ?is the disc supposed to sit that far back is it same offset back to other side?need pic other side to compare
    VT V8 berlina
    Jan 2010
    Quote Originally Posted by Asmodai78 View Post
    Id have to agree,,,,,,,sounds as if you have the wrong disc/hub combo for sure
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
    Ok, so I guess I'm going to have to replace the front left hub, any ideas on rough pricing from wreckers?
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Just replaced both front hubs today on VR with ABS and the old ones had the spigot like the photo above and the brand new ones had the same spigots as your photo - I thought the spigots were normal?
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
    after doing a little searhing for parts, is it possible my 95 vs vacationer v6 doesn't have Abs, and the last owner replaced the hub with a abs hub???
    vs commodore
    Oct 2009
    Tamworth NSW
    If its got ABS you will see the ABS modulator system in front of the brake master cylinder.Some VS's didnt have ABS.Mine doesnt (thank god).
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
    Yeah I don't recall seeing any abs system...etc, which makes me think that someone put abs hubs on...
    vs commodore
    Oct 2009
    Tamworth NSW
    Even so, ABS or no ABS,it shouldnt make any difference to which wheel will fit,they should both be the same as far as I know.Ive never heard of them being different.
  15. #15
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    I dont know,maybe they are different.Ive been looking at google about it but have found nothing yet.Someone on here would know for sure though.Which lip is it you mean exactly,can you mark it in the pic with paintshop or similar and repost it?
  17. #17
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    sounds to me like the edge of the hub is just peened over a bit and the alloy rim is a tighter fit than the steelie and hence wont go on...grab a flat file and run it over the lip to round it up and a bit of emery on the inside of the rim and retry it...i cant see how a disc is causing the prob when the disc only sits over the hub just like the rim does...the rim doesnt sit on the disc just butts up to it...
  18. #18
    Nov 2003
    You may have ot wiggle it on. The mags on my VT are wiggle on fit over the hub that protrudes throught the disc.
  19. #19
    ETH4N's Avatar
    1995 VS Commo
    Jun 2006
  20. #20
    vs commodore
    Oct 2009
    Tamworth NSW
    That part should all be the same size.I thought they were all like that.My VS has ones like that.Id like to see a photo of your other one,you say its different and doesnt have it..I know the disk can sieze on there as it just slides over that like the wheel.Maybe its a bit rusty and built up a bit. Although it doesnt look like it .The wheel should slide straight over it.Its got me stuffed mate.Hopefully someone can tell us all whats going on there with it.Cheers.
  21. #21
    Vr Exec BT1
    Mar 2010
    Agree with the above - clean the rust off the spigot and clean up the the inside of the mag wheel - if possible measure both with vernier calipers, this will tell you for sure if it will slide over or not.
    Please show a photo of the other side as I'm totally intrigued as to what is fitted.
  22. #22
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    In the top of your pic where the yellow line almost touches the spigot there looks to be an adge like its bee hit with a hammer, so as said before clean all the rust and scale from the spigot and the inside of the wheel and maybe run a file around the edge of the hub.
    Some wheels are a tight fit and other are not same with spigots from different suplliers.
    All the front spigots are the same wheel hub size (70mm) from VB-VZ with the the only difference being the brake disc hole size in VT-VZ being 71.5mm but there is a step for the disc to sit on but the wheel hub is still 70mm.
    If the same wheel fits on any or the other hubs front or back then the problem is definitely with the hub spigot.
    By the way does the brake disc slide off and on ok.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  1. VN wiring problem, any ideas.....?
    By freyja_28 in forum Electrical Wiring / Questions
    Last Post: 10-11-2009, 06:50 PM
  2. My 1998 VT Executive, IDEAS IDEAS
    By 98VTExec in forum General Discussion
    Last Post: 22-09-2009, 01:10 PM
  3. different width wheels and flat bottom steering wheels?
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2006, 05:50 PM
  4. hmmm front tyre problem i think!!!, just look and reply with ideas
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2005, 08:27 AM
