Results 1 to 4 of 4
Thread: Temp light in VS
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Default Temp light in VS
    Ok I fitted a series 3 cluster into my 95 VS acclaim about a year ago now, and ever since the day I put it in, the temp light has been popping up on the dash every 5 or so minutes, and makes a beeping sound each time it comes up. I'm trying to sort it out now because I'm trying to sell the car, and it's annoying to people who test drive it and havn't learnt to block it out. I'm thinking it's something to do with wiring, can anyone enlighten me? Thanks.
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I think someone on here mentioned this was a symptom of a dry or broken joint at the voltage regulator in the dash. *confirm?*
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    bulb and chime removal will work
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VS Acclaim S1
    Nov 2008
    Quote Originally Posted by markovr View Post
    Haha not a bad idea actually, how do you remove the chime though?
  1. How to bypass the hazard light switch (temp rewiring)?
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2011, 05:17 PM
  2. water temp light problems
    By ryanst8o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2010, 10:49 AM
  3. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  4. is the engine light ment to come on once the temp has gone over half???
    By mike49 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2009, 02:40 AM
  5. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
