Results 1 to 9 of 9
Thread: VR Oil Pressure Light
    VS SS V8 Ute
    Nov 2009
    WA
    Default VR Oil Pressure Light
    I had just degreased and sprayed down my engine then went to go for a drive and noticed that my oil pressure light lit up and didnt go away, i checked my oil and its rite on the full mark.. whats the problem? maybe the water from the wash upset something electrical? any way ill check it in the morning, maybe it'll go away once its dried out abit.
    VS SS V8 Ute
    Nov 2009
    WA
    vs commodore
    Oct 2009
    Tamworth NSW
    I have never had it happen myself but Ive read on here about plenty of people who have. Water gets in the oil pressure sensor and causes a short which causes the light to come on.Give it a couple of days to dry out.If the oil pressure was really low the engine would be rattling its head off ,you would definitely hear and notice it.If it is rattling dont drive it,it will destroy it.If the engine sounds ok and your gonna drive it while the oil light is on (whilst the sensor dries out)make sure you keep a good check on the engine sound.If the engine sound changes at all you know its and not just the sensor.You can also take it to someone and get the oil pressure checked to make sure its all ok and within spec if you want.They will just connect an oil pressure gauge to the engine and read the oil pressures.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    i did this in mine too, was thinking the worst (rebuild time) but after some research on forums i worked out that the pressure switch disagrees with water. though n my case it didn't come good again and i bought a new switch
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS SS V8 Ute
    Nov 2009
    WA
    VS SS V8 Ute
    Nov 2009
    WA
    thanks fellaz for the peice of mind, o know for sure that the pressure isnt low and it drives and sounds like it just had a service, good to know as i have to drive 400 km back home today.
    VX II Calais LS1
    Jan 2010
    VS SS V8 Ute
    Nov 2009
    WA
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Quote Originally Posted by taylorsvr View Post
    ok cheers, i shall pick one up today
    Water gets inside the switch through a small hole ...there should be a seal around the wires and it has ribs to prevent water or oil getting inside...but just take the switch out and spray it with a rp7 or inox and let it run inside and then leave upside down and all the liquid will run out or blow out with air and next day it should all be good again.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. v6 vs oil pressure light at idle
    By c@l@is in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2009, 01:18 PM
  2. VK oil pressure light
    By 85berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-02-2007, 08:14 PM
  3. 5ltr - oil pressure light not working
    By lowrida56 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2006, 08:52 PM
  4. oil pressure light! HELP
    By commodoryhory in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2005, 08:10 PM
  5. Oil Pressure Light On
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2003, 12:16 AM
