Just wondering what the hidden values are on a standard 5L.
What i mean is that if you hold the set button down it gives you a screen of cal? another screen of flow rate? and another screen of something else.
Would someone please let me know coz mine has been altered and i just want to reset it to standard.
To get to the screen you turn on ignition so everything lights up and hold set button for a cppl seconds.
Then it gives u a screen with a reading and what its for. DONT PRESS ANY ARROWS OR UP/DOWN!
Once done press menu to get to the next screen reading and so on till all 3 readings have been done.
I would appreciate it alot if i could get the standard readings.
Cars avg fuel use is like 10L/100km from the reading. Which is def not right. Just want to change it so it is more accurate.
Barbs
The readings should be set to 625 for flow and distance. thats factory. That should get it close for you.
Link -----> VN L3 Calibration - How To!
and 3 Dangerous non ABS VN's
