Results 1 to 11 of 11
Thread: intermittent problem vs s2
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Default intermittent problem vs s2
    vs acclaim v6 driving fine stop at the lights and occasionally it will surge splutter almost stall then it's fine again, a couple of times sitting at the lights and it just turns off with no warnings at all like flicking a switch the engine stops, start it again all is good again, a couple of times slowing right down to pull over or go through roadworks and it just switches off with no warning.
    my mate recently got a vs exec and I asked him how it's all going he said all good except the same problem we are having as above but no surging at the traffic lights.
    any ideas would be much appreciated.
    Nobody wants to play with me
    xCalliba's Avatar
    xCalliba is offline EPICVN
    VT 9C1 5.0L & VN 'S' Pack project
    Mar 2008
    Kyabram, VIC
    injectors could be blocked or have crap in them? same scenario with my VN ages ago, use to stall and splutter randomly, then one day it just stopped, and refused to kick over. i pulled the injectors and fuel rail out, got them cleaned up, threw it back in and rans sweet ever since. worth a try?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    worth a try,
    I was also thinking something electrical though.
    VX II Calais LS1
    Jan 2010
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    I was just looking at the cas on ebay and thinking $50 odd dollars seems ok and if thats not it I would have a spare cos it will go eventually. any idea how much for a genuine one at trade price I've only got vl ones before and that hurts.
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    No, all the dash lights come on after the engine cuts out then we start it again and everything is fine. until next time. there is no telling when it is going to do it and the same when it surges forward, but when it surges forward it splutters and almost stalls but doesn't then corrects itself and all is fine again.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check for logged fault codes first - this will give you an indication of what is wrong. Instructions are at: Checking error codes VR/VS (Revised)
    vs berlina s2
    Feb 2009
    mine did this. it also u know what when i fixed the o2 earth problem. it never logged codes but scince i earthed the sensors the problems totalty gone.
    VR Commodore S 5-speed
    Mar 2010
    Wilton, nsw
    vs commodore
    Oct 2009
    Tamworth NSW
    Sounds more like a faulty CAS (Crank Angle Sensor)as mentioned above.It would be the first thing Id be replacing or checking/testing if my car had these symptoms.A very common problem on the V6.
  1. VT Intermittent Transmission Problem
    By squiddley_diddley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 08:56 PM
  2. VR Intermittent Engine Problem
    By Swift in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2009, 09:44 PM
  3. Intermittent starting problem
    By jeff62 in forum Electrical Wiring / Questions
    Last Post: 05-05-2008, 07:39 PM
  4. Intermittent starting problem
    Last Post: 20-04-2008, 02:04 PM
  5. Intermittent Engine Problem
    By Sir-Psycho-Sexy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-10-2007, 11:39 PM
