Results 1 to 3 of 3
Thread: Speedo Sender - How to reinstall
    VR Commodore and Honda Jazz
    Apr 2010
    Default Speedo Sender - How to reinstall
    Now that the wires have been cut and the speedo sender thing is not in the gear box. What is the best way to put it back on. The wires don't seem to hold inside the plastic clip thingy very well. The previous owner just stuffed the wires in the holds and pushed the plug into the switch. Any idea????
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe get some heatshrink tubing ,a soldering iron and solder and also a second hand plug.Solder the other plug from a wrecked car to the cut wiring.Then shrink down the heatshrink tubing over the joins to seal out moisture etc.Seeing as its under the vehicle use heatshrink instead of electrical tape to cover the joins.It seals and insulates the join, lasts forever and looks heaps tidier and than tape..
    Apr 2010
    Small problem the wires are really hard to get at? Is there another way to get to the wires other than from under neath the car.
  1. speedo sender
    By ryan1980 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2009, 07:08 PM
  2. Leaking speedo sender unit.
    By joe_rolls_commo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2008, 01:29 PM
  3. manual box speedo sender - same for N/A and Turbo?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2007, 10:14 PM
  4. Ok so reinstall old air con...? VK
    By viper1431 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-11-2005, 07:35 PM
  5. WTB - VN-VP T5 speedo sender
    By vkberlina in forum Swap / Wanted to Buy / Trade
    Last Post: 20-07-2005, 04:29 PM
