Originally Posted by
deanos70
as bret said do the welch plugs, they are only about $20 a set
i just had my motor and box out on the weekend and replaced my rear main seal, only about $32 from bursons for the seal
when you put the new seal in it has to sit between 4.2mm and 4.7mm from the rear face of the seal to the rear face of the crankshaft flange, if you sit it in to far the rear main bearing cap oil return will be blocked and the seal will leak
when your getting the old one out becareful if you are using screwdrivers you dont want to put burrs or grooves in the crank or it will leak too, also check the crank for any burrs before you put new one in, it is bit of a bugger to get the old one out so you dont damage the crank, but just go easy with it
its surprising how much the old engine mounts sag, when i put my new engine mounts on i thought i had the wrong ones as they looked like no way they would line up back in the mounting holes in the k frame , i had to leave them pretty loose and the aircon bracket loose as well only finger tightened the bolts on, then engine lower them down and lever them into place then tighten it all up, its a bugger to do
if your old aircon is still gassed up, undo your air compressor from the engine, leave all the hoses attatched and push aside, saves you a regas afterwards, i also down that with the power steering so i didnt have to refill / bleed and saved the oil running everywhere
if leaving the loom on when you are pulling the engine out, dont forget to undo the earth wire from the body near the battery, and also the small fuse / relay panel on the battery side of the main fuse / relay block there is a little flap you can open up and with a 10mm socket undo the power cable
i found it a lot easier to take the throttle body and accelerator cable plate off when removing the engine as well
also for the sake of about $22 replace the sump gasket it would be a bastard to do later in the car, while the sump is off clean it and the oil pick up ,
the amount of sludge i found sitting in the bottom of mine that doesnt come out in an oil change is amazing, and the oil pick up was half blocked up with crap as well
