Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Vr auto rev limit
    hq-racing's Avatar
    hq-racing is offline HSVR-28
    93 VR CLUBSPORT WAGON DAILY. 73 HQ PREMIER PROJECT
    Sep 2008
    S.A
    Question Vr auto rev limit
    hey ppl, ive just bought a VR Clubby wags and ive noticed a problem with it changing gears.
    the car has a vt 5.0 in it running the vr trans but the computer has been remaped for the car. the trans has also been rebuilt wit a stage 2 kit.
    the problem is when changing gears it hits the limiter and dosent change till i back off. and it hits the limiter bout 6200..
    it also dosent like staying in 2nd at low revs, it keeps droping back to 1st then into 2nd.
    i thought it maybe 1 of the following but need some more ideas.
    1- my vs b4 this vr use to do the similar thing when the exhaust was standard and the cat was blocked. the car is running a 2 1/2 exhaust system and extractors but it recently went thro defect and has had a restriced muffler on it. mine use to get stuck on the limiter but it didnt keep changing from 1st to 2nd.
    2- maybe the remap is playing havok on the gear selection and needs to get looked at.
    3- might be that the throttle body pressure on the trans is to tuned to hard and needs to be backed off.
    i was thinkin of geting these things looked at or even getting a manulised trans kit put through it so it changes when i want, or a manual....
    any light shed on the matter would help out heaps..
    thanks guys.
    VX II Calais LS1
    Jan 2010
    sounds similar to a problem ive been having with the auto in my ss, mine just holds 2nd gear all the way to rev limiter until i back off for a few seconds (5-10secs), delcowizzid suggested adding a shift kit which im thinking of doing but you already have one?? mine also jumps down a gear then straight back up at low speed.
    Ive tried replacing the TPS in mine to no effect and all the other basic stuff.
    Good luck and keep us posted if you find the problem.
    hq-racing's Avatar
    Sep 2008
    S.A
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    vs commodore
    Oct 2009
    Tamworth NSW
    Does the 5.0 engine run a Throttle Position Sensor(TPS)?On a V6 when these play up they can cause all sorts of problems with the shifts as the transmission uses signals from the TPS to shift properly.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Brett_jjj View Post
    yes the V8's do, there interchangeable with the pre-ecotec V6 ones
    hq-racing's Avatar
    Sep 2008
    S.A
    never played wit TPS b4 where is it? how do i change? and how much ruffly?
    VX II Calais LS1
    Jan 2010
    its on the bottom of the throttle body, 2 torx head screws hold it on and 1 wiring plug, there pretty simple to get off and can be done with the TB in place, i removed my TB when i changed mine tho so i could clean it. they cost around $50 for a new one you could do what i did and get a known working one to test on your car any thing from a VN-VR V6 and V8 and VS V8 are the same part hopefully it will fix your problem but it had no effect on mine.
    hq-racing's Avatar
    Sep 2008
    S.A
    yae cool will give it a sus 2moz, ive still got my vs 5.0 in da driveway so ill use that 1. idz let ya know how i go..
    hq-racing's Avatar
    Sep 2008
    S.A
    baa no real difference, still holding gear for way too long, im gona go 2 my trans guy 2moz n ask him wat he rekons..
    vs commodore
    Oct 2009
    Tamworth NSW
    With my V6 it will hold the gear shifts way into the redline if its held flat through the gears.It sorta seems like its not gonna change up at all until it finally does at the "very last minute" so to speak.
    hq-racing's Avatar
    Sep 2008
    S.A
    my actual bounces on da limiter, or just stays on red, real bad 1st to 2nd.
    vs commodore
    Oct 2009
    Tamworth NSW
    No good like that.As you said,go see the trans guy and see what he says.Let us know how you get on.
    hq-racing's Avatar
    Sep 2008
    S.A
  15. #15
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by hq-racing View Post
    same with mine mate, but mine holds 2nd gear to the limiter if im above half throttle.
    Just been on to my local trans center and they want $525 to pull my valve body apart and replace all parts in it.
    Let me know how you go with yours.
  16. #16
    hq-racing's Avatar
    Sep 2008
    S.A
    mine dosent do that, it does hold it rev a lil longer than normal to change 2 2nd. just a pain when you wanna giv it sum stik..
    i have noticed a bit of play in the shifter, does ne1 knw wat that could mean and would it explain the problem im having??
  17. #17
    hq-racing's Avatar
    Sep 2008
    S.A
    well took it to the trans guy 2day and all the readings r fine, no dramas. he rekons now that it has to be a computer problem. gonna take it to a remapping place n get them to sus it! baaa...
  18. #18
    hq-racing's Avatar
    Sep 2008
    S.A
    updating my issues with the trans for ppl wanting to know, i went to my dyno place the ota day n i had the auto elect look at the computer and it has no problems! he put a standard 1 in and still the same! they beleive its a trans problem. they rekon it might be a stuffed or blcked valve coz of the way it holds it pressure n dosent want to change. i have now spoken to another trans guy and he rekons the same thing.
    im getting the trans looked at nxt wk and i will let ya know the verdict!
    VR CLUBSPORT WAGON
    yes a clubsport wagon....
    LIVE THE DREAM
  19. #19
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Stick a bog stock ECU on and take it for a bash, It will tell you whats going on, If it doesn't do it, there is your problem, if not I would be looking elsewhere.
    Ben
    There is no such thing as stupid questions, Only stupid people.
  20. #20
    hq-racing's Avatar
    Sep 2008
    S.A
    he done that n it still ran the same, if the trans guy cant find a fault then i will take it another computer guy.
    VR CLUBSPORT WAGON
    LIVE THE DREAM
  21. #21
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    If another ECU didn't change the problem, then a computer guy can't help. I would be looking at other things, see if you can get a hold of someone who owns a Snap On Analyzer, they might be able to pin point it.
    Ben
  22. #22
    hq-racing's Avatar
    Sep 2008
    S.A
    the last trans guy ran a check and nothing came up, everthing was ok. this other trans guy is gonna take it appart n clean it change the filter n oil n have a look at the valves.
    VR CLUBSPORT WAGON
    LIVE THE DREAM
  23. #23
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Thats another thing, Is it low on oil???
  24. #24
    VR 304
    Mar 2009
    Are you running an airflow meter or map sensor?
    What about dissy and manifold what sort. As you say
    it has a VT roller cam 304 so these things mentioned are
    also different.
  25. #25
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I'd be replacing the TPS before you spend any more money.
    THROTTLE POSITION (TP) SENSOR
    REMOVE
    1. Disconnect battery earth lead.
    2. Remove throttle body assembly.
    3. Remove two TP Sensor attaching screws using Torx bit.
    4. Remove sensor from throttle body taking care not to loosen the drive adaptor, washer or spring.
    5. Remove drive adaptor, washer, spring and washer.
    REINSTALL
    1. Reinstall washer, spring, washer and drive adaptor to throttle valve shaft.
    2. With throttle valve in the normally closed idle position, install TP Sensor on to throttle valve shaft and throttle body at a position 30 degrees clockwise past throttle body attaching screw holes.
    3. Rotate TP Sensor anti-clockwise on throttle body.
    4. Install TP Sensor attaching screws and tighten to the correct torque specification 1-1.5Nm
    5. Reinstall throttle body assembly.
  1. rev limit??
    By arex7 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2009, 07:43 PM
  2. 253 rev limit
    By Nobody Actually in forum V8 Development and Modification
    Last Post: 09-11-2008, 01:49 PM
  3. Age limit for pub
    By one_and_only2004 in forum The Pub
    Last Post: 26-03-2008, 10:08 AM
  4. What is the VZ SS rev limit?
    By onefifty in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-11-2006, 08:24 PM
  5. limit??
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 10:34 PM
