Results 1 to 2 of 2
Thread: Help m30 gearbox probs
    Vr accliam
    Apr 2010
    Default Help m30 gearbox probs
    Help my gearbox in my 1996 vr acclaim auto is playn up on me. It's an electrical fault as I've just replaced the gasket & filter & there were no metal shavings , all clear . Wots happining is it refuses to shift 1st,2nd,3rd & if allready in 3rd or 4th it refuses to kick down when I plant my foot. However it will kick dwn when say u approach an intersection but wotever gear it selects it will not change up from there . Also when sitting in neutral or park & I select either drive or reverse bangs into that gear rather harsh.
    vs commodore
    Oct 2009
    Tamworth NSW
    Try swapping the Throttle Position Sensor (TPS) for a known good one.When this sensor wears out it can stuff up the shifts and cause the box to play up as the auto transmission uses the signal from the TPS to shift properly.
  1. well try it again hey....gearbox probs
    By gav555666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2010, 09:56 PM
  2. ABS probs
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-11-2009, 12:50 PM
  3. vr 95 sII executive gearbox probs
    By hearnie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2009, 08:19 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. vs gearbox probs
    By NVE_069 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 12:00 AM
