Okay i have wiring going threw the firewall where the pedal box will go. where can i run these wires now?
number 2 i havent got the manual wireing harness can i change mine to work so i can use the speedo and reverese lights i have the original t5 computer/ecu just no loom
and question 3 how do i find the neutral switch and make it so it will start?
ive done a search for all of these items either people have asked and had no reply or havent been answered properly. thanks for your help guys much appreciated![]()
The neutral safety switch is next to the auto gearshifter just under the centre console.I think its also the reverse light switch but not 100% sure on that.
Have you had a look through the VN-VR manual conversion guide?
Most of the questions are answered there if you read right through it.
As for running wires where the clutch cable went, I drilled a hole just above it and put a grommet.Looks good also.
