Results 1 to 4 of 4
Thread: VS V8 Radiator Fan
    nvo
    nvo is offline
    Jan 2009
    Default VS V8 Radiator Fan
    I have a VS V8 radiator in front of my Nissan Navara that has a VT V6 donk in place.I am running at the moment an aftermarket 2750CFM fan thats mounted onto the radiator with those plastic cable type ties.The ties are wearing into the radiator water tubes.
    Question I have as silly as it might appear is
    "Does a VS V8 Commodore run the same fan confiquration as the VS V6 Commodore.Are the CFM of both fans the same?
    regards Andrew
    vs commodore
    Oct 2009
    Tamworth NSW
    The V6 uses a thermo fan,the V8 fan uses a viscous clutch setup thats driven by the engine.If your not getting enough cooling from one thermo fan,maybe add another thermo fan next to the one thats already there.Some commodores had a different electric fan again that went on the front of the radiator as well as the one thats in the usual place.Maybe get hold of one of them.I think it was only fitted to earlier commodores (VN/VP) that had air conditioning.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Brett_jjj View Post
    They were fitted to some VR/VS aswell, my VS V8 has the small thermo fan in front of the rad, as did my VR statesman.
  4. Default
    a lot of the 5ltr boys fit el/ef/au twin thermos to their radiators. apparently they are the perfect size, so that's a good option as well. as said above, the 5ltrs run a clutch fan off the water pump.
    Quote Originally Posted by zai View Post
    I am not sutpid
  1. Radiator VN serie 2 (radiator cap) on a serie 1 (no raidator cap) ?
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-12-2009, 12:07 PM
  2. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  3. Radiator fan help
    By slickster_91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2008, 11:36 AM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
