hey guys
lately in my vr v6 commodore sometimes whilst driving and on startup the battery light came on and off and there was a whistling sound from the engine. i got told that it was most likely my regulator on the alternator. so i had a spare alternator sitting around and took the regulator off that. the bushes wernt that worn out. so i swapped them over and now when i start my car the battery light is on All the time and wont go off..
what have i done?
cheers guys
Just get another alternator,either second hand or a rebuilt unit.Noise from an alternator is mostly caused by worn bearing(s).Maybe you should try the other spare alternator you mentioned.Also the main charge wire that connects to the rear of the alternator is known for corroding from heat and causing problems,its worth checking it out too.
There are 2 types of pedestrians, the quick and the dead
Check out my ride here....
http://forums.justcommodores.com.au/...rlina-ls1.html
Reco alternator = WIN.
cheers fellas
just picked up a ful reco'd 1 for 75$![]()
