Results 1 to 10 of 10
Thread: VS Commodore Diffs
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    Default VS Commodore Diffs
    just wondering if the auto and manual commodore diffs were different, and if they are is there a way of telling. I got a wrecked VS manual ute here V6 all i want is the conversion but if it for instance has a LSD or lower ratio diff than what the hell might aswell put that in. Can anyone fill me in more. If there is a way of telling could someone put some photos up for me telling me what to look for.
    Thanks Guys
    VX II Calais LS1
    Jan 2010
    ute diffs wont fit a sedan. If it is a LSD it should have a tag on it saying high performance lsd.
    ethann's Avatar
    ethann is offline Low And Luxurious!
    '11 WRX, '73 Stingray, Lifted/Locked GQ.
    Dec 2009
    Newcastle, NSW.
    Quote Originally Posted by bandit10 View Post
    Why won't a Ute diff fit a Sedan?
    Assuming both are live axle they would be interchangable?
    I thought VS Sedans still same in live axle.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by ethann View Post
    Different mounting points/brackets for the shocks
    Ute+wagon = interchangable
    Sedan = not
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    Can't i just change the diff centre. ie pull the axles out take old diff centre out, replace with new, can i not do this i am under the impression that they are centres are the same. Yes i do have live axle.
    VX II Calais LS1
    Jan 2010
    VS Acclaim
    Jan 2006
    Diff centres for these diffs are the same from vl turbo through to vt series 1 and also from what i hear, some skylines and also fords (28 spline borg warner). Someone please correct me if i'm wrong.
    This includes irs and live axle
    VS Ute
    Apr 2010
    So by reading this can I replace a standard diff centre with a LSD centre if they are both from a Ute or Wagon (I have a basic model vs Ute)
    VX II Calais LS1
    Jan 2010
    you can get a LSD center out of anything sedan/wagon/ute/live axle/IRS all the centers are the same.
    If i was you i would just buy a whole replacement diff for your ute that has a LSD center installed already, you can pick up good LSD's from the wreckers for around $300.
    They are easy to change if you know what your doing it can be changed in 30 mins easy.
    You need a complete diff out of a wagon or a ute to fit your ute, sedan ones wont fit.
    vx clubsport r8
    Mar 2010
    i have changed several diffs to suit the opposite vehicle sedan to ute wagon to sedan by grinding the welds that hold the shocker mounts on till it separates them from the diff and re-welding the required shocker mounts to diff you have to be a good welder though. i think this is better than dismantling the whole diff to change center.
  1. vr and vs abs diffs
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2009, 04:39 PM
  2. Commodore Diffs
    By echnidna in forum General Discussion
    Last Post: 07-07-2009, 11:40 AM
  3. diffs
    By commnz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2005, 10:23 PM
  4. Vl Diffs
    By VBSL79 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-02-2004, 08:50 PM
