I managed to remove the window winder clip, but what is the best way to reattach it? also, im having a hard time removing the red door lock tab aswell - any tips?
thanks heaps.
If you are good you can get the window winder clips out with a bread and butter knife also, easiest way i have found without making/buying tool.
And smurftec is onto it with the rest. Sometimes i find 1 of those really really smal flat blade screwdrivers or a pointy knife works for the locks. and i just put the clip in place on the winder bfore pushing it back in place works (the spline has a taper which the clip pushes over)
