Results 1 to 8 of 8
Thread: Series 1 VS chewing oil
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Question Series 1 VS chewing oil
    My series 1 VS has ALWAYS used engine oil but just lately it's become a little worse. I usually have to top up close to 2 litres every 5 or 6,000k's Strange thing is it doesn't blow any smoke so I don't know where the oil is going. I know series 1 VS's have always had a habit of using oil because Holden tried to use softer seals to help fuel ecomomy but at a cost of oil consumption. The car now has 365,000 k's and still runs perfect except for the oil issue. Do i need the seals replaced or just live with it?
    VT
    Apr 2005
    QLD
    its not doing too bad considering the kilometres on the clock. do you drive it pretty conservatively or not? it might be worth while to change the valve stem seals maybe?
    EAT 4LT TURBO Guest
    Vr's Were Bad For Valve Stem Seals I Bought A 97 Vs Statesman Superchargedv6 And Had It For Six Months And It Had 92.000k's And It Used 1.5lt Oil In 5,000k's And Was Faultless I Got Sick Of It So Got The Ss And It Has Not Used Any Oil Between Changes In 2 1/2 Years
    2x VS
    Jul 2005
    365,000 km's !!!!!! Original Engine ?
    Does it still have piston rings ?
    lmao
    Regards,
    sixshooter
    Mar 2005
    South Coast, NSW
    Quote Originally Posted by sixshooter
    lmao
    Regards,
    sixshooter
    Pretty much. Was owned by a machinery company out west. Driven by the boss and all highway k's up until that point. In its first 3 years it had racked up 161,000k's. At 110,000k's it threw a conrod through the block so it had a "short motor" put in. Don't ask me how it happened, this was before I bought the car. Even still it's been a damn fine reliable car, and still looks great after a polish and wax.
    VX S Pack L67
    May 2005
    What oil do you use? Thicker oil would be more well suited for a worn engine, I think 20w50 is what's reccomended for VS but thinker oil woudn't hurt.
    EAT 4LT TURBO Guest
    Yes 20w 5o Is The Right Grade Oil And Thicker Oil Does't Hurt Either I Use Penrite
    Mar 2005
    South Coast, NSW
    I've always used Castrol GTX2. Except I tried Valvoline XLD premium about four months ago. Seemed to use only slightly more oil with XLD. Last weekend I went back to GTX2. I've always changed the oil at worst 10,000k intervals. Usually around 7 or 8000. I figure whats the point in toping it up when I'm just gonna change it anyway. I wouldn't say it was a "worn" engine either. Apart from using extra oil it still runs perfect.
  1. series 2 vq with series 2 vn motor, almost stalls between park and reverse and drive
    By sp001in in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2011, 11:49 AM
  2. which models had tyre chewing problems?
    By ascension24 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-01-2009, 10:55 AM
  3. Tyre chewing problem solution
    Last Post: 12-06-2006, 04:03 PM
  4. Chewing Out Rear Tyres
    By Brumbies 5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2006, 11:26 AM
  5. Chewing up fanbelts
    By Rickvsv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2005, 09:34 PM
