Results 1 to 7 of 7
Thread: HELP lol changing ignition barrels
    VR commodore
    Mar 2010
    Default HELP lol changing ignition barrels
    im changing my ignition barrel after my vs getin stolen!!
    i bought one from the wreckers and have the one that was on there..
    the one thats on there seem to work fine but to b on the safe side im changing it.
    i put the new barrel on and hooked it up but it seems to lock the steering wheel n nothiing i do even when putting the key in n trying to unlock it works the key wont even turn
    does neone now wats going on????
    vs commodore
    Oct 2009
    Tamworth NSW
    Was the key in it,and was it in the "ON" position when you inserted the barrel?The key has to be in the barrel,and it has to be turned to the ON position before its inserted into the steering column.
    VR commodore
    Mar 2010
    VX II Calais LS1
    Jan 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    Sounds like the wrong key for that barrel.It should be able to turn to all the positions -off,accessories,on,and start.
    VR commodore
    Mar 2010
    yep def have the right key... it was working yest but the sec i changed it the new one would work so i put the old one bak in n same thing happens!?
    vs commodore
    Oct 2009
    Tamworth NSW
    How are you installing it.Is the key in the barrel and the barrel in the ON position when you install it??
  1. Changing VY ignition barrel
    By Carlton95 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-01-2011, 06:27 AM
  2. Changing ignition barrel light
    By Verynice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2009, 06:59 PM
  3. Worth changing ignition leads?
    By sprocket in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2009, 09:39 AM
  4. Dicky key barrels
    By [OUTSIDER] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2005, 10:52 AM
  5. vn ignition barrels
    By blowera1 in forum V6 Development And Modification
    Last Post: 16-07-2005, 01:35 AM
