hey
ill be cruising doing about 80 km or higher and when i go to excellerate i hear a grinding or crunching noice under the floor.sounds like my gearbox or something.anyone got any ideas?
any help will be appriciated cheers
manual or auto? does it sound like its coming from the gearbox area, engine or diff?
its auto and its sounds like the gear box.i can feel a little bit of vibration in the excellerator
4th gear gone?
- --FS - SI VL Calais Turbo (no Motor) Good Project -- -
when you say accelerate at 80 k's, does the gearbox kick back and then the noise?
yea it kicks back then a grinding noise
Jack the car up and have a look at your drive shaft center bearing.. the insulating rubber could be pooched..
This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
If it's not the centre bearing, check the rear engine mount although if it were either you'd imagine it would be heard whenever you floor it. How are the plugs/leads? - these can misfire when cruising then accelerating which initially seems like the torque converter clutch is failing.
ok cheers ill have alook tihs weekend . get back to yas
