Results 1 to 9 of 9
Thread: signs of a blocked catalytic converter
    VX II Calais LS1
    Jan 2010
    Lightbulb signs of a blocked catalytic converter
    What symptoms or signs would you get from a blocked catalytic converter?
    Anyone had this problem? what did you notice?
    VT spac super6
    Nov 2008
    Riverton sa
    Youll start loosing power, engine wont want to rev..
    what signs are you getting?
    VX II Calais LS1
    Jan 2010
    No sign's as such, just wanting to hear other peoples experience with blocked cats to see if anything sounds familiar
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Kurtp View Post
    Have you tried to give the tranny a service first? =|
    And checked the error codes?
    Yes i have thanks, that was the 1st thing i did
    This thread is not about my transmission thought, its about blocked cats.
    I was hoping to hear from people that have experienced a blocked catalytic converter and the symptoms it produced
    Thanks
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Dont know if mines blocked or not but it rattles like hell. Sounds terrible, its off the road for now though.
    Best RPG ever
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A blocked cat will reduce performance and increase fuel consumption. The sound will also change to a "ffffttttttttt" sort of noise. The engine pipes will get really hot too. The easiest way to tell if you ahve a blocked cat is to do a temperature test, if it is hotter at the front of the cat, it is blocked, if it is the same temp front and rear, it is not working or it's hollow, if it is at least 10% hotter at the rear it is working.
    Drive the car hard around the block, then while holding the revs up to 2000rpm, test the cat.
    Visit my Facebook page
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Awesome advice thats mate, now i just need to find a thermometer suitable to do the test.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    An exhaust shop will have one and a cat test is usually free.
  1. catalytic converter
    By vrfireman in forum V6 Development And Modification
    Last Post: 12-02-2010, 04:42 PM
  2. catalytic converter
    By StatOmaN in forum General
    Last Post: 10-02-2010, 10:59 PM
  3. need a catalytic converter in S.A
    By omaz78 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2008, 11:57 PM
  4. Replies: 4
    Last Post: 21-06-2008, 12:40 PM
  5. VX S S/C6 Catalytic Converter
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2006, 07:35 PM
