Results 1 to 7 of 7
Thread: Tappets...
    '97 VSII Executive V6 Auto
    Aug 2009
    sydney
    Default Tappets...
    would noisy tappets be silenced with a rocker and rod change?
    my engine;s making a tapping noise that's proportionate to the revs and load, coming from the driver's side rocker cover, just behind the alternator (i think, mate has also told me the same)..
    not losing any power etc, just annoying,
    if they are left alone what will happen
    if they need replacing how much would that be
    if the engine needs opening, would changing the rockers and rods solve the prob as well as pick up some extra horses and foot pounds?
    vs commodore
    Oct 2009
    Tamworth NSW
    How often do you change the oil and filter.Try some fresh 20w50 oil and a new oil filter and add some lifter free up additive like wynns brand or similar..The lifters can make a tapping noise when they get gummed up,usually caused from the oil and filter not being changed regularly.The lifter free up additive helps remove this gum and crud from the lifters and their bores etc.If you do use this additive make sure the engine gets a good rev out to get the oil circulating through everything at its maximum pressure,that way everything gets a good cleanout.(only give the engine a good rev out if the noise seems to improve and quieten down after the oil change and adding the additive.Reving an engine that has a rattle is not always a good thing to do to it,it might not be lifters ,it might be something more critical like a bearing,if the oil change ,filter and additive make no difference at all to the rattle,then dont rev it too hard at all until youv'e investigated it further)
    VS 304 efi
    Jul 2009
    Changing rocker arms and pushrods won't give you extra power, it'll just return it back to normal unless you get roller rockers or whatever. Check and change your oil before you do anything else. Your lifters may be starved for oil or have gunky old stuff blocking them - if that's the case (and it's been happening for a while), you'll need to replace them too (or repair them if you know what you're doing). Pushrods generally don't need replacing unless the tips are flogged out.
    Skidney's Avatar
    Skidney is offline Utes do it better.
    VP UTE
    Sep 2009
    Adelaide CBD
    Aug 2009
    sydney
    I change the oil and filter every 8000kms, using valvoline premium XLD 20W50 and ryco z154 filter, my last oil change was around 3000kms ago (i average around 1000kms a week).
    I'm not sure it's an exhaust leak but the tapping seems to come from just behind the alternator.
    it's an annoying tapping sound.. not losing performance/economy (500-600kms/59L tank in w.syd)
    if i was going to open the engine up, i'd get the 1.98 rockers and the pushrods.
    vs commodore
    Oct 2009
    Tamworth NSW
    If the oil is fresh, then as I mentioned previously,try a lifter free up additive.
    Aug 2009
    sydney
    tried the addittive, apart from making the engine a little quicker to rev, didn't change anything...
    took it to a mech.. turns out it was a leaking exhaust manifold gasket.. an $80 job... sweet
  1. VN- VR tappets
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2010, 05:00 PM
  2. noisey tappets(i think)
    By craig vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2009, 01:56 PM
  3. Replace tappets in VR
    By Jezmont in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2009, 03:44 PM
  4. Tappets???
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2006, 08:48 PM
  5. VL 6CYL Tappets
    By Doogs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-10-2004, 01:07 PM
