Results 1 to 23 of 23
Thread: changing rear FE2 springs - what am I doing wrong?
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Default changing rear FE2 springs - what am I doing wrong?
    Hi all, went through the "how to's" and changed the rear shocks no problem, except the flat on top of the shockie rod sheared off when undoing it but nothing a hacksaw and chisel couldn't fix. Followed the forum and thought the springs would fall out with a bit of a battle, but no go - had diff sitting on the trolley jack and body on chassis stands BUT left hand brake on, is this a big no no as I have since read? Checked the ellery's and it says drop the lower control arm - 1 bolt from what I can see. Any help or comments appreciated.
    thanks Tony
    VX II Calais LS1
    Jan 2010
    live axle?? if so body on stands, diff hanging free, undo lower shock bolt, get mate to stand on hub to push down, pull spring out!
    vs commodore
    Oct 2009
    Tamworth NSW
    Sit the car on chassis stands and let the diff hang free.Put a jack under the lower arm just enough to take the spring tension, then undo the rear lower control arm rear bolt,remove the bolt then lower the jack and the arm will drop down so you can get the spring out.When re assembling dont tighten the rear control arm bolts until the weight is back on the control arms.(once the car is back on the ground).
    Vr Exec BT1
    Mar 2010
    VX II Calais LS1
    Jan 2010
    VP Executive R-spec
    Jan 2005
    vs commodore
    Oct 2009
    Tamworth NSW
    Should just pull out with the body jacked up and the shocker undone
    Usually the standard type springs arent short enough to do it this way.If lowered springs are fitted you can usually get them out like you said just by jacking up the body.
    Vr Exec BT1
    Mar 2010
    Thanks Greenfoam, but I can assure you it was far from falling out with the rear end chassis stands fairly high - think I'll try dropping the lower arm as I'm doing it on my own.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Brett_jjj View Post
    ive pulled many a standard spring out this way. (just undoing the shocker, with a mate pushing hub down)
    vs commodore
    Oct 2009
    Tamworth NSW
    The ones Ive done with standard springs wont come out unless the arm is lowered.Like the guy just said," but I can assure you it was far from falling out with the rear end chassis stands fairly high ".The workshop manual also says to lower the control arm to remove the spring.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I am a lazy bastard, I would just buy a $40 spring compressor from SuperCheap .
    Ronald Reagan (1986)
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by acarmody View Post
    Its easier to undo a bolt and lower a jack than it is stuff around with a spring compressor.
    VP Executive R-spec
    Jan 2005
    I dunno maybe you have giant springs, country pack or something. I can always pull a standard spring out easy enough, you might just have to stand on the hub to make sure it's are low as it goes. I haven't had to remove the trailing arm yet and I've done it a few times. It's supposed to be a 15 minute job in theory (I haven't used stands just jack one side like you are going to remove the wheel, then pull the spring out, then do the other side, maybe one side at a time gives you an geometric angle advantage )
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by greenfoam View Post
    Ive done it this way heaps to foamy, even with wagon and ute's that have "country pack" springs (longer than sedan) lol
  15. #15
    VP Executive R-spec
    Jan 2005
    Well it has to come out, it's a spring it bends to anyplace you want , just a matter of holding it right
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    I know when I put new FE2 springs in my VS it had the standard springs and I had a prick of a time trying to get them out and ended up following a manual and undone the control arm bolt.Now when I jack the car up I can pull the springs out with my hands ,They are just sitting there and just about fall out once the car is jacked up.The FE2's are heaps shorter that the ones that I took out.
  17. #17
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    anyone noticed that when you put fe2 rear springs in a solid axle car it will lower and soften it enough so if you put 2 people in the back seat your exhaust and anything in the way will hit on speed bumps and it will sit on the bumps stops as the springs are actually softer than standards?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  18. #18
    VP Exec
    Jun 2005
    One more thing: a reminder, with lower springs and standard bushes, to loosen and retighten the control arm bolts at the new ride height to avoid winding up the bushes more than absolutely necessary.
  19. #19
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    .....and dont stretch the rear brake hose.
  20. #20
    Vr Exec BT1
    Mar 2010
    Thanks everyone, removed lower control arm bolt and then spring virtually fell out - new springs fitted all good.
  21. #21
    wa90de's Avatar
    wa90de is offline wa90de
    VP SS 5 Pegger
    Sep 2009
    Central Coast
    If any one could help me, that would be great.
    I got a heap of new gear for my VP SS with irs and was wondering where is
    the lower control arm bolt to help me get the rear fe2 springs out?
    Also, is it hard to replace front struts and springs myself?
    Thanks
  22. #22
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Wa90de, as said above your FE2 springs should come out if you undo the shock and pull the wheel down .. just make sure you don't damage the brake hose or rubber boot on the axle. You have IRS so its totally different to the live axle rear end and you don't have lower control arms. The Front is more complicated, and depends if the struts and springs you bought are already assembled or if you need to compress the spring and swap any bits over. Try the back first
  23. #23
    vs commodore
    Oct 2009
    Tamworth NSW
    As I mentioned above to the other guy ,with most of the live axle commodores that I have removed the standard or FE2 rear springs from,I have had to undo the rear lower control arm bolts to lower the control arm a bit, and then remove the spring.It takes about a minute to undo it, so its certainly no big deal.Once shorter springs have been fitted ,they will nearly fall out when the rear of the car is jacked up.Another thing, remember to fit the the control arm bolt /nut loosely while the car is supported up on stands or whatever. Only tighten the control arm bolt back up once the weight is back on it and car is sitting on the ground. It can flog out the control arm bush if tightened up whilst jacked up..
  1. Changing rear springs vyss
    By richierich in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-10-2009, 02:47 PM
  2. Changing VH Wagon Rear Springs ?
    By Secki in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-08-2009, 12:42 PM
  3. [QLD] swap Solid axle springs for IRS springs for the rear - Goodna
    By Gus The Snail in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2009, 07:59 PM
  4. Changing springs in a vx
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2006, 11:25 PM
  5. Changing Springs?
    By Shifty1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-12-2005, 12:40 PM
