Results 1 to 14 of 14
Thread: Front strut bolts - re-use or replace
    Vr Exec BT1
    Mar 2010
    Fortitude Valley, Brisbane
    Default Front strut bolts - re-use or replace
    Hi all,
    going to be changing my front struts in the next week or so and I have read (from genuine Holden workshop manual) that the two lower main bolts must not be used as they are tightened to a pre load state ie. the nut stretches the bolt. Being a fitter, I find this a bit ludicrous as in my line of work if bolts are pre loaded they should have a shoulder on them to prevent over tightening and possible bolt failure. BUT, I am not a mechanic - is this correct what Holden advises and if so can I buy them from a bolt shop?
    thanks in advance
    Tony
    VX II Calais LS1
    Jan 2010
    If thats the case you would have to get new bolts every time you get a wheel alignment done as you have to loosen the 2 lower bolts to adjust the camber on the front end.
    You can re-use the old one's, ive never had any issues with doing so.
    No doubt someone else will tell you they must be replaced thought.
    vs commodore
    Oct 2009
    Tamworth NSW
    The camber is adjusted on the hubs of VR/VS.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by Brett_jjj View Post
    The camber is adjusted by a bolt on the hubs of VR/VS. not on the lower control arm pivot bolt
    who's talking about lower control arms..??? no one that i see of..
    To adjust the camber on VR/VS you have to loosen the 2 big bolts that go through the bottom of the strut that attach it to the hub assembly before any adjustment can happen.
    VX II Calais LS1
    Jan 2010
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    I replaced my struts a few weeks ago. The new struts came with new bolts + nuts.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Vr Exec BT1
    Mar 2010
    Thanks guys, I'll just use the same bolts - it's not a race car. No wonder dealers bills are so expensive.
    vs commodore
    Oct 2009
    Tamworth NSW
    I didnt take notice of the question properly, I thought you was talking about the centre pivot bolts.Trying to keep up too many posts.Plus 100 kids running around me yelling.It gets confusing sometimes.Anyway as for the bolts that hold the strut to the hub assembly,Ive re-used them before no worries.I wouldnt re use them too many times though.Maybe 3 times max.Then Id replace them.
    VX II Calais LS1
    Jan 2010
    lol i wondered where you got bottom arms from.. last time i checked they wasnt connected to the struts
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by bandit10 View Post
    yeah,funny that.I lost the plot with that one hey.
    VX II Calais LS1
    Jan 2010
    lol finally cracked ay.. might be time to put the work shop manual down and move away from the computer hahaha (jokes*)
    vs commodore
    Oct 2009
    Tamworth NSW
    I would loose it then if that ever happened ,all I get to enjoy these days is my computers and my cars.
    VP Exec
    Jun 2005
    They are meant to be replaced each time they are loosened, which includes a making a camber adjustment. It doesn't seem to be a disaster if they are not - I wonder what the FOS is on them?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    yes, those 2 bolts are torque to yield bolts. that is the bolts have been tightened to a point greater then there ability to stretch and return to there standard length when released. read this. this is for headbolts but the principle is the same
    having said that. i have also re-used and not had issues with em.
    the best advice i can give is that you re-use the old ones when you fit the new struts, then take the car for a wheel alignment and have them fit the new bolts so that all is set for trouble free motoring
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Can i replace my power window door rivets with bolts?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2009, 03:08 PM
  2. How to replace front strut top on a 93 VP S2 (easy way?)
    By samn3000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2009, 07:46 PM
  3. Front Strut Bolts
    By Phil257 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2009, 01:16 AM
  4. Re-use or replace bolts ? callipers, Zbar etc
    By greenacc in forum General
    Last Post: 30-12-2008, 07:31 AM
  5. Strut bearing, how to replace it?
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2006, 11:13 AM
