Results 1 to 6 of 6
Thread: coolant temp sensor (done search)
    vs berlina s2
    Feb 2009
    Default coolant temp sensor (done search)
    I have done a manual conversion on my v6 vs s2 had the engine out to do rear main, engine mounts, welsh plugs and a heap of other gaskets. but now engines back in has a full manual loom/computer but comes up with error code 14. the sensor is less an 3 months old and has not been a problem untill tonight. anyone got any ideas? (error code 14 coolant temp sensor low voltage)
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd check that the wiring is correct and the ECU see's the CTS it by disconnecting the connector then turning engine on....fan should start after 12 secs on LO then after a short time go to HI. If that checks OK I'd remove sensor and measure resistance in hot water. Specs are in Gregorys.
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    Check that you haven't left one of the EARTH terminals from wiring loom off the back of the left head. Some of the newby apprentices forget this too... Can take ages to find if your not onto it..
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    vs berlina s2
    Feb 2009
    weird as all shit this is. i replaced both sensors all good did about 100km and its come back again :S
    vs commodore
    Oct 2009
    Tamworth NSW
    Were they cheapie ones or genuine holden sensors? When it comes to sensors Ive seen a few problems with the cheapie sensors,I always buy genuine holden sensors.They are a bit dearer but you get what you pay for usually.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Did you run the checks I suggested?
  1. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  2. where is the coolant temp sensor?
    By 300zx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2008, 11:01 PM
  3. Coolant temp and o2 sensor?
    Last Post: 02-10-2005, 02:05 AM
  4. Coolant temp sensor
    By v8bike in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2005, 08:05 PM
  5. Coolant Temp Sensor
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-04-2005, 05:47 PM
