i was wondering if a sedan tank from a VT would fit in place of a vr wagon tank. looking at pictures they look similar but un sure about dimensions. wiring up the pump and running lines shouldn't be a problem.
mmmm.....maybe.
VT has the inlet/outlet and wiring at the top and the filler neck is part of the tank. May need some cutting of the floor.
Why the swap??
im surprised no one has made plastic replacment tanks yet with a bigger capasity as an option
If the vt tank won't fit get itself some if this PPC
it does an awsome job of cleaning ur tank and then it comes with a coating for the inside of ur tank so it can not rust
