Results 1 to 4 of 4
Thread: couple of questions
    Vs SS
    Jul 2009
    Default couple of questions
    hey just want 2 ask couple of questions
    what do you think i sould do my fuel hoses near the left fuel rail and along the back on my motor seem 2 always crack is there some other hose i can get 2 reduce it from cracking and ive notice couple of my fuel injectors are leaking was wondering if the o ring might be stuffd would i be able 2 replace just the o ring or do i need 2 get new set of injectors 4 it
    whats a decent battery going 4 these days 2 get the 5liter going and how much and whats the best leads and spark plugs these day 4 dual fuel 5 liter
    vs commodore
    Oct 2009
    Tamworth NSW
    Battery is around $120 for a decent heavy duty one.If the injectors are leaking externally onto the top of the engine, the injector o rings will probably need replacing.(check the fuel rail etc as well).If the injectors are leaking fuel into the engine then new injectors will be needed.Any cracked fuel hose should be replaced if you dont want it catching alight.The fuel system runs at fairly high pressure,so it wont take long for a cracked hose to let go completely.
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    replace the fuel lines for sure and maybe wrap with heat proof tape id say it is the heat in the bay doin it
    Vs SS
    Jul 2009
    yea been thinking about changeing them but whats puting me off they got some stupid clamp on them and know what els i could use 2 clamp the hose on the joint any ideas
  1. A couple of VZ questions
    By stockyvrcalais in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-09-2009, 09:07 PM
  2. couple questions??
    By Escape-The-Fate in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2008, 09:26 AM
  3. couple of questions...
    By SICKTG in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 08:51 AM
  4. couple questions
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2007, 11:18 PM
  5. Couple of questions - regarding my VC
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-01-2007, 05:35 PM
