Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By hq-racing
Thread: Second hand LSD problems.
    Deneo's Avatar
    Deneo is offline Lock your Daughters up
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Default Second hand LSD problems.
    Hey guys
    Brought an lsd of some shady lookin C*** off Egay.
    Put the lsd in and thought it was good, Now after driving it for about 5 mins it starts to get a mad whine/scrape sound up.
    Also when reversing the first time i got a mad clunking sounds 2 times sounded like the gears locked up or something.
    Anyone know what the problem could be? needs a decent service?
    Thanks.
    Holden VN SS
    Mar 2010
    id never buy a second hand lsd or diff dude, its only like $1100 to get your diff gears changed and lsd recoed or shimmed.
    VS Calais
    Mar 2010
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    its screwed, and if it wasnt screwed just had no oil in it and you've driven it, its screwed now. pretty much better luck next time
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Some tipped out of the breather but other than that no i havn't checked, Will tomorrow morning.
    And i had no choice ss, Had an open wheeler in a 5.0 and im on a tight budget, Payed 150 for the diff.
    Feb 2006
    Radelaide
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    MMmm I think what you are hearing is whats called diff chatter.
    This is caused by the Limmy slip cones binding to the differential end gears.
    This is a common problem with Holden LSD Diff's after a oil change and is not a big problem to fix.
    GMH have a product called Diff Chatter Pack which is just re-labeled
    Penrite LIMSLIP ADDITIVE 7098
    Used to alleviate problems associated with chatter in all limited slip and spin resistant differentials.
    So you can save your self a lot of cash by getting the stuff from Penrite direct and giving the expensive GMH re-branded stuff a wide birth.
    LIMSLIP ADDITIVE 7098 - Penrite Oil
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Eh,
    I'm a complete nob, The LSD has no F***** oil in it. Well, I think.
    If i stick half a coat hanger in through the fill hole on the side, It should be neally to the top of the hole right?
    Holden VN SS
    Mar 2010
    they need to be filled to the bottom of the filler plug, when u check it make sure the car hasnt been driven all day otherwise you wont get an accurate reading..
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    I drove it about 200 meters to hear the sound again and nothing, But still, I got the coat hanger to the bottom of the diff pan and no oil at all.
    vs commodore
    Oct 2009
    Tamworth NSW
    Dont drive it until you get some proper LSD oil in it.The damage might already be done though.
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Holden VN SS
    Mar 2010
    a bit over 500ml I think, not quite sure. i used the whole bottle plus a bix extra to get to the bottom of the filler hole.
  15. #15
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    sweet as, i'll get some first thing tomorrow. Thanks for the help fellas.
  16. #16
    VS Calais
    Mar 2010
    hq-racing's Avatar
    hq-racing is offline HSVR-28
    93 VR CLUBSPORT WAGON DAILY. 73 HQ PREMIER PROJECT
    Sep 2008
    S.A
    Quote Originally Posted by zapper-l67 View Post
    do you just put that in or mix it with diff oil?
    whats a good lsd oil to use?
  18. #18
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Put the oil in, Still go a whine in the diff but not as bad as before. Since then iv'e developed a sound from the front of the car, Im thinking i just torch it haha.
  19. #19
    VS Calais
    Mar 2010
    I would mix the additive with the diff oil. Is the sound from the front coming from around the gearbox? If so I would check the drive shaft.
    Good luck.
  20. #20
    Sladdo is offline Resident Ford mechanic
    HBD VT V6 5sp Exec.
    Jan 2009
    Murwillumbah
    Maybe do a few oil changes till its good?? Maybe it never had an oil change before. Gave my LSD a few oil changes when i first got it only cuz it looked as if it had sat out in the weather for a bit. Turns out to be a great LSD - really tight. I change the oil every 10,000km though. After a long drive my diff gets that chatter but I heard when you put that additive in it loosens them up a bit?? Is that chatter bad for the diff?
  21. #21
    zapper-l67's Avatar
    VX Calais
    Jan 2010
    Western Vic
    Quote Originally Posted by hq-racing View Post
    You didn't think before you wrote that did you. LOL
  22. #22
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You'll need around 1.65l of oil. Castrol SAF/XA (synthetic) is the recommended oil and doesn't need any additive. Alternatively you could use cheaper oil like Castrol LSX90 together with an additive.
  1. My new second hand SS
    By Hunter SS in forum VE - WM
    Last Post: 04-05-2009, 03:49 PM
  2. [SA] Second hand OTR
    By HRT 666 in forum Parts And Other Items For Sale
    Last Post: 01-03-2009, 02:14 PM
  3. VX SS LSD how much second hand?
    By ozengines in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2008, 12:06 PM
  4. In My Hot Little Hand
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:41 PM
  5. I Need A Bit Of A Hand
    By Kim in forum General
    Last Post: 19-02-2004, 10:14 AM
