Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: If anyone can tell me what's wrong with my car they're a genius
    96 VS Acclaim
    Mar 2010
    Default If anyone can tell me what's wrong with my car they're a genius
    So I made a thread yesterday about my car not starting. Read it here if you haven't seen it already Car not stating (again).
    So, today I get a new starter motor as per instructions and fit it in. Easy job didn't take long. Problem is car still makes the exact same noise.
    A basic run down:
    Got a new battery
    Water pump was leaking - bought a new one arriving monday
    Decided to do a cooling system flush
    Took thermostat housing off to get thermostat out for a new one
    Put coolant cleaner down top radiator house
    Put housing back on with no gasket or thermostat in
    Started car (it started fine) and noticed coolant cleaner spraying everywhere from the housing
    Stopped car, cleaned up coolant and put a new gasket in as well as thermostat
    Tried to start car and NOTHING!
    What the hell happened? I got told starter motor so I got a new one, but still nothing.
    Here's a video of the sound it's making.
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    maybe the teeth on the flywheel are worn or starter motor is getting stuck, are the battery terminals tight? coolant change has nothing to do with this imo.
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    sounds like its not getting enough power ..... the vecheals at work when they have a flat battery make that noise ... ummm thinking
    do u have a volt meter?
    vs commodore
    Oct 2009
    Tamworth NSW
    Have you checked the "START" relay under the bonnet near the fuses,this relay supplies the starter solenoid with power when the key is turned to start.Just swap it for one of the other relays that are the same type, such as the horn relay, and then see if it starts.Also does the engine actually turn over by hand?
    96 VS Acclaim
    Mar 2010
    I just cleaned the battery terminals and still nothing. I tried to jump start the car with my brothers yesterday and still nothing. I just don't understand how it can work one minute and not the next.
    Feb 2010
    Tamworth NSW
    trying jump starting again put run your positive straight to the starter motor and negative to any good sort of earth on the vecheal .... almost never fails =)
    Dec 2007
    nthn suburbs, vic
    take out the starter and hook up the wires and get someone to turn the key as u hold it, see if it works it could be faulty even new. if it works or even try this first, rotate the motor by hand by putting a socket on the crankshaft then try again.
    Feb 2010
    Tamworth NSW
    96 VS Acclaim
    Mar 2010
    Quote Originally Posted by Brett_jjj View Post
    Have you checked the "START" relay under the bonnet near the fuses.Just swap it for one of the other relays that are the same such as the horn relay and tyhen see if it starts.
    Swapped relays and still nothing.
    05 Calias
    Apr 2010
    Tas
    is it an auto or manual? if its a manual put it in gear and try and move the car a little bit to get different spot on flywheel, see if that helps ???
    96 VS Acclaim
    Mar 2010
    Quote Originally Posted by 1FATVT View Post
    i just had a thought, is it auto ?
    Yeah its auto
    Feb 2010
    Tamworth NSW
    your netural sensor might be ****ed ... if all else i've said fails. check where your neutral sensor is... and replace it .... =)
    VS Senator
    Oct 2009
    96 VS Acclaim
    Mar 2010
    Quote Originally Posted by Clint_G View Post
    could be the solinoid on the starter motor.
    already changed starter motor
  15. #15
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
  16. #16
    Feb 2010
    Tamworth NSW
    just try what i said, try jump starting direct to the positive of the starter motor and the earth lead somewhere solid on the car as a earth and try that. if that dosn't work, go to the neutral sensor on your transmission ... then if that fails ... eeep
  17. #17
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    You stated that coolant sprayed everywhere... did the DFI module or the ignition coils get wet by any chance? They do not like to get wet.
  18. #18
    BoNeZ-01's Avatar
    BoNeZ-01 is offline "..of mice and men.."
    '95 Cino(daily driver), Project: VS.
    Mar 2010
    Central West, NSW(middle of nowhere).
    That sound is familiar, but only time I've ever heard it is either a dodgy starter motor/solenoid, or not enough power to turn it properly.
    You say it's a new battery, so I'm assuming not that.
    But you also say new start motor, so shouldn't be that either, although dud new starters are possible, but then so are dud new batteries.
    So just in case, to eliminate anything else, I would say to disconnect your battery, and check every electrical connection you can find in your engine bay which 'may'(even if unlikely) have gotten wet.
    Give them all a quick spray of WD40 and blow them dry, just to be on the safe side, since, as you said, this problem started after* spraying the engine with cooling system flush.
    Short of that, try pulling out all of your spark plugs, then try turning the motor over, just to make sure nothing is in the cylinders stopping it form turning over.
    It may be a pain in the bum, but maybe pull the new starter back motor off and check, as has been mentioned, that the teeth on the fly wheel have not been chewed off at the spot where the starter motor is trying to engage.
    All I can come up with at this point..
    On the 7th day, God created Holden, then on the 8th day, God created Ford, to keep idiots out of Holden's.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost..
    wtf? im not stupid, theres no such thing as a tyre valve
  19. #19
    vs commodore
    Oct 2009
    Tamworth NSW
    The DFI module or coils if stuffed, wont stop the engine from winding over.
  20. #20
    VS Senator
    Oct 2009
    Quote Originally Posted by deXtrous View Post
    was it a brnd new one or reconditinoned. and the solinoid could still be fulty from new
  21. #21
    96 VS Acclaim
    Mar 2010
    Bosch made in Argentina
  22. #22
    vs commodore
    Oct 2009
    Tamworth NSW
    Remove the starter and power it up with jumper leads from the battery.You will soon see if the solenoid is working or not.It sounds like a power supply problem,thats why I suggested checking the start relay.It supplies power to the starter solenoid when the key is turned to start.Ive seen them cause similar issues.
  23. #23
    Feb 2010
    Tamworth NSW
    my earily sujestion about the neutral sensor, scrap that, tried starting my sisters VT up in 3rd ( its a auto ) and it dosn't make any noise at all ... so umm yea back to the drawing bored .....
  24. #24
    96 VS Acclaim
    Mar 2010
    Alright so I was fiddling around and turned the car to gas (forgot to mention it was LPG) and tried to start it.
    The machine gun ticking noise stopped now it ticks ONCE and then a high pitched noise is heard. The LPG turnover gauge light switches off and doesn't come back on until I take the key out and put it back in.
    Now when I even try to start it on petrol it doesn't do anything, just the high pitched noise and turns off the turnover gauge light..
    Attached Thumbnails Attached Thumbnails If anyone can tell me what's wrong with my car they're a genius-dsc04506..jpg
  25. #25
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    your battery is stuffed. what does your interor light do when you try and start the car...you can have 12v on the battery but the cca (cold cranking amps) could be stuffed seen it many times. and when jump starting the bettery is fused out and not getting through.
    swap the battery over and see what happins
  1. Was I wrong?
    By Calaber in forum The Pub
    Last Post: 24-04-2009, 05:35 PM
  2. Please Tell Me What Is Wrong With My Vs
    By narooc99 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2007, 04:12 PM
  3. Genius!!!
    By fourstar82 in forum Jokes/Humour
    Last Post: 19-03-2006, 09:08 PM
  4. Pure Genius...
    By VT-565 in forum Jokes/Humour
    Last Post: 19-07-2005, 03:23 AM
